Intertherm BDM35 fireplace. Pilot is lit and valve is set to ''on'' but it won't light off right away. Changed the batteries in the wall switch but still no change. Sometimes you turn it on and it will come on within a minute other times you could leave the wall switch on for an hour or so before the thing will light off. For some reason the gas valve is not opening until it feels like it. any ideas?
2 Suggested Answers
  • 2598 Answers
SOURCE: intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Posted on Jan 02, 2010
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Intertherm fireplace model bdm35
Check the thermocouple, it generates the electrical power from the flame of the pilot to open the gas valve.
Dec 10, 2013 | Heating & Cooling
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
I have a Marco gas fireplace model# 794019C. It is the millivolt pilot generator type. I first changed the thermopile and cleaned the spark ignitor to get it to light. I have checked continuity and...
Mike, I suspect that the problem you're having is not related to the new Thermoplie (Pilot Generator) you installed. Its with the Thermocouple. The clue was "Some of the time its hard to keep the pilot light lit". The Thermopile controls the opening and closing of the gas valve, when the wall switch is turned ON/OFF. The Thermocouple, is what keeps the gas valve open and pilot light lit all the time. If there's no flame heat on the Thermocouple, it closes the gas valve. Rather than replace it, you can try polishing it with some very fine sand paper, then wipe the tip with a cotton ball soaked in alcohol. If the Thermocouple is really pitted, don't attempt this. Just replace it. If you do replace it, when you make the connection to the gas control valve, finger tighten the nut, then tighten only 1/4 turn more with the appropriately sized wrench.
By the way, MARCO is no longer in business as MARCO Fireplace. It was purchased by Lennox Hearth, a division of Lennox Heating. And your model firsplace is no longer manufactured. If you continue to have problems with it contact Angie Parrish at Lennox via email angie.parish@lennoxhp.com.
Hope this helped you solve the problem. Please be kind enough to rate my response to you. Thanks and have a good day!
Mar 25, 2011 | Heating & Cooling
How do I turn on my superior ventless fireplace
I'm not sure about that brand, but I finally figured out how to turn the one in the house I just moved into. The only visible control if you have not accessed the fireplace controls before is the switch on the wall. The wall switch is strictly an on off switch, but it only works if the pilot light is already lit, and the pilot light will not go out by turning off the wall switch. To access the controls, first pull out the vent covers, they are simply held in place with pressure buttons on each end. Behind the lower vent are the controls for the pilot light and fire intensity, mine also contained a metal plate with the instructions printed on it. Open the glass door by opening the four latches, two on top and two on bottom, and then swinging it out on its hinge. You will find the gas spout for the pilot light hidden between the logs. Turn on the main gas line by turning the straight edge of the red handle parallel with the gas line. Turn the gas control to pilot, by pushing in and turning, and then push in all the way to start gas flowing. I like to have a match already lit next to the valve when I start the gas. After the pilot light has been on for about 60 seconds let go of the button and it will return to its normal position. Then turn the control to on and turn on the wall switch, the main burners should start lighting. Close the glass and put the vent covers back in place and your ready to enjoy the fireplace :)
Nov 27, 2010 | Heating & Cooling
Intertherm gas fireplace, model BDM 35, pilot goes out
Jan 02, 2010 | Heating & Cooling
Help troubleshooting an FMI GL-850E Gas Fireplace
It sounds like the Ignition Control Module went out, as I've heard the vibrating noise you speak of just before the module "dies." You most likely have the gray Robertshaw control module box located under the fireplace connecting the power to the gas valve. You will need to have a Certified Gas Fireplace Specialist look into this issue and replace, if necessary.
Dec 07, 2009 | Heating & Cooling
How do I light the pilot on my InterTherm MGBB 070 furnace? I have tried holding in the pilot switch but have had no success in getting the pilot lit.
Just to make sure you are trying to light the pilot, from the gas valve follow the small diameter pipe (1/8") to the pilot assembly. Where you should be placing your flame is above that point. Now with the gas valve knob turned to the Pilot marking, depress the know into the gas valve. Light the pilot. Check to see if it is lit and remain holding the knob in for 30 to 45 seconds. If the flame goes out as soon as you let out the knob, you will need to replace the thermocouple.
Oct 11, 2009 | Heating & Cooling
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
154 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
