Lots of shower valves have pressure balancing cartridges nowadays in order to get full flow out of hot or cold you have to have both the hot and cold hooked up to give even pressure on both sides of the cartridge that should fix your problem and give you a full flow
most commonly the evap systems vent solenoid is plugged or inoperable causing pressure to build in the fuel tank as you fill up. this high pressure triggers the gas pump nozzle to shut off as it would if the tank had been filled. replace canister vent
Make sure the hot water is turned back on. Pressure balancing valves won't work if both cold and hot water is not on. Pull shower head off and test to see how it flows out of the shower arm. If good, clear out shower head. Whenever water is turned off for a time, and then turned back on, restricting shower heads and aerators usually get clogged. In the future, always open up a tub spout before turning water back on. This releases the air and other debris most effectively before testing other fixtures in the house.
It sounds like there is quite a bit of sediment in the water. The filter you are using may be a very fine micron 5-10. Try using a 30-50 micron filter. RJ
push start o.k.? Has it been sitting for awhile? bad gas maybe ...try fresh gas then some Seafoam fuel system cleaner... if you can get it running. also it might have a weak battery...trickle charge it four five hours then try again......battery votage after trickle charge should be minimun 13v.
Without knowing the brand or model number I can't help you, it is most likely that you need to adjust the pressure release valve so give the information and I will get back to you.
