Question about GE DBSR453EBWW Electric Dryer
My GE dbsr453eb2ww dryer temp only go as high as 140 degress and it takes allday to dry clouthes
  • 78 Answers
I would think one of the elements is burned out, i would replace them both, get on e bay and put your in fo in model serial number and you can buy them, and have shipped to your door, thks larry
Posted on Apr 26, 2010
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
Model # DBSR453EB2WW; sounds as if belt needs lubrication when operation dryer, high pitch sqeeking. Please advise.
The belt is attach only to the motor pulley and a tensioner pulley one of which is most likely in need of replacement...you could oil or grease them but that probably wouldn't last very long or work at all...??
Apr 19, 2010 | GE DBSR453EBWW Electric Dryer
My dryer used to shut off before the clothes are dry - now it wont start at all
Ok, the light will not come on if the door pressure swicth is damaged and, the dryer will not start if this switch is damaged as well. replace the door pressure switch asap.
Ok, concerning the interuppted drying cycle due to high heat, this can be cuased by two issue. It coudl be a venalation issue. if the dryers vent duct and exuast hoses are clogged, thsi will cuased the element to reach unsafe tempreturs, in return, tripping the high limit thermostsat and shutting the dryer off in the middle of the load cycle.
Another problme spot woul dbe a fualty high limit thermaostae. Although this is highly unlikey, this coudl be your issue.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jun 02, 2009 | GE DBSR453EBWW Electric Dryer
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Electric heating elment.
Somewhat,
I have a ref. thermometer, round metal type I got a Wal-Mart that I check the dryer temp at the discharge. I bent the metal bottom so I can lodge it in the discharge pipe, turn the dryer on and watch the temp. Normally on high heat it will go up to 140-150 and cool down to 120-125 then cycle back on.
Jan 24, 2009 | Estate EED4300SQ Dryer
My dryer shuts off before the clothes are dry.
when the dryer shuts off immediately check all 3 sensors w/a ohm-meter to see which one is open. That will be the one causing your problem.
Jan 03, 2009 | GE DBSR453EBWW Electric Dryer
Electric Dryer runs/heats but takes double the time to dry than normal.
The temp is between 153 deg and 189 deg and yes there is a tech mode.
Jun 29, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
GE DBSR453EBWW Electric Dryer Logo
266 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
