Question about Nokia N91 Cellular Phone
N91 I have N91 4GB 1 year old.My cell phone always off and on even i update new version at nokia.com.what i m going to do?
  • Anonymous Apr 26, 2008
    hi! i have nokia n91 4GB for almost 2 yrs now and i cant use it often anymore cos its always turns off & on every now and then while im using it...
  • Anonymous Jun 15, 2008
    themes from the internet are not opening on my n91 mobile and showing error msgs what will i do my handset is 1.5 yrs old........
    Sergeant:
    Champion:
  • 230 Answers
Menu>Tools>Hard drive>Options>Tools>Format hard drive
Formatting the hard drive will clear any data stored on it. This should be a last resort and we'd suggest trying to scan the hard drive first. This will attempt to fix any hard drive disk errors. If your N91 does not have the scan option (some don’t) then connect to your PC in mass storage mode, right click on the F: drive, then hit scan.
Posted on May 11, 2008
I want to update nokia e5
You need active internet connection for this:
1. press #0000#, then it will display you the current software version that your phone is using.2. press option, then select check for updates.3. it will then go to connecting to internet, select yes.4. if there is available update, you will be provided instructions that the phone is updating software.5. you will be ask to replace the old version with the new version, just select YES.6. your phone will restart, that's part of the software update.7. after restarting, your phone will now be using the latest version available for your phone.8. you can again check the current version of the phone's software by entering *#0000#, then you are good to go.
You can also try to this:go to settings --> software update --> download available updates --> phone will restart --> you will be using the new version of the phone's software after this.
Thank you for choosing www.fixya.com
Dec 08, 2011 | Nokia E5 Cell Phone
Software update
You can:
1. type *#0000# to check the current software installed in your phone.2. select options then select check for updates3. if there are available new updates just select start update.4. follow the process for software update.
You can also:1. go to settings2. select icon for "software update"3. it will provide you access doing the update to the latest version available for you phone4. start update5. follow instructions for update
*you can also update via pc suite from your pc, you need to download the latest pc suite from nokia.com/softwareupdate*you can go to www.nokia.com/software update then select your phone model and the just follow the instructions
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
Nov 29, 2011 | Nokia 1280 Cell Phone
I want to update it software version via USB cable
Nokia 6300 firmware update
Subject: how to update firmware for Nokia 6300 to the latest official version
1. You need download and install NSU - Nokia Software Updater (http://europe.nokia.com/support/download-software/device-software-update/download#) and run it to ensure that all is ok! (don't forget to switch on and connect Nokia 6300 via USB with PC)
2. You need to download and install NSS (Nemesis Service Suite) (http://www.b-phreaks.co.uk/index.php?main_page=page_2), the latest version of NSS was 1.0.38.15 (select "Virtual USB Device" mode)
3. Close NSU if it's not closed and load NSS then click icon "Scan for new device"
4. Click icon "Phone Info" and button "Scan" inside it
5. If all is ok you'll see some lines with Phone Version, Phone IMEI and so on
6. Click button "Read" and remember your "Product Code"
7. If your want to clean your phone go to tab "Tools" and switch to subtab "Factory Setting", choose option "Full Factory" then press button "Reset" (NOTE!!! all personal data and settings will be cleared!)
8. Return to tab "Phone info" and type in the field "Product Code" the following code 0537621 (or any code from (http://www.expansys-usa.com/ft.aspx?k=96957)) for version 7.21, or code 0557624 (or any code from (http://www.a2phone.com/6300-rm-217-dp20-900-sw-0730exe)) for version 7.30, select option "Enable" then press button "Write"
9. Close NSS, run NSU
10. Now NSU should update firmware to version 7.21/7.30 (or any latter build) (http://europe.nokia.com/support/download-software/device-software-update/can-i-update)
11. Repeat stages 3 - 5
12. Type in the field "Product Code" the code that you remembered before, select option "Enable" then press button "Write"
13. Close NSS
14. Use you clean phone with new firmware!
Mar 17, 2010 | Nokia 6300 Cellular Phone
I usung nokia 6300 and iam dowloding opera .opera not work my nokia 6300 and how to up grade my nokia 6300
hi may be the opera you are downloading is not suitable for your handset its better for you to not download opera
I bought Nokia 6300b RM-222 with firmware version 4.71, but now the latest firmware is 7.30 (or any latter build). But Nokia Software Updater (link) told me that I already had latest firmware and refused to update my phone. Below I described the steps to upgrade Nokia 6300b RM-222 from version 4.71 (or any other version) to version 7.21/7.30 (or any latter build).
13. Close NSS
Mar 15, 2010 | Nokia 6300 Cell Phone
Phone wont turn on but it does light up
Many new phones seem to be having problems with the firmware needing to be updated because of the shelf life being so long. The phone may be new but the firmware/software could be a year old or older requiring a firmware update. If you have the cable, you may be able to find an update on nokia's website, otherwise the wireless carrier.
Dec 07, 2009 | Nokia 6700 Classic Cell Phone
Nokia n70-1 gets hanged
You need to download the latest Nokia PC Suite, from the Nokia website of your area to do an update of the software (firmware) on your phone.
http://europe.nokia.com/A4144905
Before updating software you should check that there’s a newer version of software available.
http://europe.nokia.com/A4176089
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Apr 05, 2008 | Nokia N70 Cellular Phone
Hello every one here
hi there you must update your N73 to a higher version using nokia sofware update. you can download here
note: to update your phone must use usb connectivity cable CA-53 and High-speed internet connection. once updating your phone do not disconnect the cable it can damage your phone.
if you can't do it just go to your nearest service center to upgrade to higher version.
ok!
peace!
Mar 26, 2008 | Nokia N73 Cellular Phone
I cant open the gallery, calendar and file manager
Dear Friends same problem here to me. i update my phone's software some days ago using nokia software updater after that i am having that problem. On old version this is working fine. But the new version sucks.
Jan 14, 2008 | Nokia 6600
Nokia N91 Cellular Phone Logo
124 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
