Question about Kitchen Ranges
Asko washer model 6532xxl getting an error h2 what could that be
  • 2 more comments
  • J-run Apr 26, 2010
    asko washer getting and h2 error, this washer is 1 month old. model 6532xxl
    it is an h2
    asko washer getting h2 error 1 month old
    thanks
    Genius:
  • 1,416 Answers
this means that your washer have locate liquid substance in it , i.e over flow of water in to the system monitor
what you need to do from here is that take note of the measurement of water and also the quantity of the materials in it to avoid over flow of h2 i.e water
after all these then you will have to some clear up on your washer
take a clean dry rag to wipe of water or the dust around your washer
then it will stop to indicate this error sign h2
Good luck and thanks for using fixya.
Posted on Apr 26, 2010
  • 776 Answers
Please let me know if that is the complete error that you see.
Does it start with an F or you are sure its an H.
Please give complete error code.
  • Dushyant Bist
    Dushyant Bist Apr 26, 2010
    When do you receive the error message.
    Normnally there are no codes starting with H....an F2 error codes means:
    F2
    :High water level
    Plugged/Bad water pump · Defective water inlet valve
W6441 Error message
google this with the model # and the brand along with the F4 error code
Jul 25, 2015 | Asko W6441 Front Load Washer
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
ASKO D1976 model. We have a F2 error message. Water has now been drained but we are unable to remove error code or have dishwasher return to normal cycle
Display shows an error code. Do the following:
1. Unplug washer or disconnect power for one minute.
2. Plug in washer or reconnect power.
3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
May 27, 2011 | Dishwashers
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore 46462 Front Load Washer
F4 error message. Cleaned out screen at water inlet and still get error message.
There may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out, Reconnect and try again. Hope this helps it works for me and saves ££££'s in repair fees
Oct 04, 2009 | Asko W6461W 24" Front Load Washer w/ Delay...
Need new stabilizer clip/bolts for ASKO washer model W6461
Don't need those bolts except for shipping the washer. They were supposed to have been removed a long time ago.
Sep 18, 2009 | Asko W6461 Front Load Washer
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Mar 09, 2009 | Asko W6021 Front Load Washer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
