Question about RC Airplane Sportsman Corby Starlet Giant Scale Plane
How many grams is in one pound? i have only a kitchen scale that measures pounds. I need to measure 100 grams serving of meat. Is this possible? right now i can not afford to buy a different scale. thank you
    President:
  • 2,309 Answers
There are 1000 grams to a kilogram,and roughly 2.2 lbs to a kilo. so mesure roughly 1/10 of of 2.2 lbs which is .22 lbs or a quarter pound hope that helps
Posted on Apr 26, 2010
  • 5,102 Answers
28 g is an ounce. So 448 g per pound. Thus the 100g serving is 3.6 oz or 0.22 pounds.
How accurate is your scale?
I hope this helps.
How much of a cup is 20 grams of granule chlorine
check the links, but best by far is an electronic kitchen scale as grams is a measure of mass (weight) and a cup is a measure of volume.
chlorine dosage calculations and measurements pool volume
www.swimmingpool.com.au/ChemicalBalanceChart.html
  1. Cached
  2. Similar
40 x 20 x 5, 12.0 x 6.0 x 1.5, 110,000 ... CHLORINE DOSAGE CHART (This chart is a guide only)DOSE PER 10,000 LITRES ... Granular Chlorine, 80 Grams ... Tables I-1 and I-2 provide volumes in drops (dp), milliliters (mL), teaspoons (tsp), ... The values moving down a single column represent how many of the units at the ...
Chlorine to prevent swimming pool water problems - POOL WIZARD
www.havuz.org/pool_pool/pool_maintenance/water_testing/chlorine.htm
  1. Cached
  2. Similar
When planning to buy a test kit to measure the chlorine levels in your pool, it is ... Take the water sample from at least 20-30 cm below the surface and at least ... As a rough guide, a pool needs about 600 grams of granular chlorine (2-3 cups) ...
How many grams of granular chlorine does a cup hold - Answers.com
www.answers.com > ... > Categories > Science > Units of Measure > Metric System
  1. Cached
  2. Similar
280 +/- 5% ... many grams in a tablespoon chlorine? Approx 20 grams ... How many cups of granular pool chlorine in one pound? 2 cups. 48 people found this ...
How to measure chemicals??? - Trouble Free Pool
www.troublefreepool.com > Forum > Swimming Pool Care > Just Getting Started
  1. Cached
  2. Similar
May 26, 2013 - 7 posts - ‎3 authors I've been using a measuring cup but I assume when hth says 8 oz....they mean 1/2 pound. ... Ha, found the answer on this video, guess they do mean fluid ounces. ... Using CYA granules for example - if my measuring cup said 32oz, that is 2 lbs, correct? ... 8638 gallon 20'x52" Intex ultra frame round AG.
How to measure Chlorine Granules? - What's The Best Hot Tub
www.whatsthebest-hottub.com > Hot Tub Forum > General > Hot Tub Forum
  1. Cached
  2. Similar
Aug 9, 2006 - 15 posts - ‎8 authors My question is, since I only have a 100 gallon spa, and the Chlorine Granules say to add 1/2 oz per 500 gallons of water, how do I know and ...
how to convert 10 grams into understandable unit? ' Yahoo Answers
https://ca.answers.yahoo.com/question/index?qid=20100527135338AAbL0Np
  1. Cached
  2. Similar
May 27, 2010 - I have to put 10 grams of powdered chlorine in my kids swimming pool ... But you can't use a measuring cup or tablespoon to measure mass ...
Nov 15, 2016 | Computers & Internet
My digiweigh scale reads 0 - LD what's that mean
Hi Douglas 0-LD means your digiweigh scales are in pounds, 0 means no weight and LD means pounds..... The link below shows how to convert LD to KGS (pounds to kilos)
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Mar 26, 2016 | DigiWeigh Measuring Tools & Sensors
What 3 tools should I use to measure 5 grams of macaroni , 10 ml of milk and 3 cm of butter?
To measure the macaroni, you are measuring mass or weight, so you would need a scale.
To measure the milk, you are measuring volume, so you would need a measuring glass or a set of measuring spoons.
To measure the butter, you are measuring distance, so you would need a ruler.
I hope this helps.
Let me know if you have any questions.
Good luck.
Paul
Sep 08, 2015 | Home
How do I measure 100 grams of peas?? I use measuring cups.
cups measure volume , you wish to measure weight. Try 100 ml equivalent , or a tiny bit more. 100ml is just over 3 ounces of liquid equivalent. In theory one ml is the same as 1 gram but the measure is for liquid. (water I think) A teaspoon full is about 5ml/5 grams. Slightly over the 100ml mark is a very rough estimate. A weighing scale really would be better
Jun 08, 2015 | Office Equipment & Supplies
How many ounces is 56.4 grams
Technically - an ounce is 1/16th of a pound. 16 ounces in a pound - generally 28 grams but exact weight is 28.349. You're at just under 2 ounces at the exact weight of 28.349 grams per ounce.
A Troy Ounce is a universal measuring method used for precious metals, gun powder, etc. - it's actually just over 31 grams and is known as an 'Imperial Ounce' (2.75 grams over the standard ounce)
Oct 01, 2014 | Home
How do I change my 100 gram weigh max scale from calibrating at 50 grams back to 100 grams?
a scale is calibrated at half it's capacity. when you use a 50 gram weight to calibrate it, it can still measure 0-100 grams properly.
Aug 15, 2014 | Measuring Tools & Sensors
WHAT IS THE DIFFERENCE BETWEEN MG AND ML
A Milligram is MG and a Milliliter is a ML. (MG) is used in dry measure and (ML) is used in liquid measure
1000 micrograms (mcg) EQUALS 1 milligram (mg)
1000 milligrams (mg) EQUALS 1 gram (g)
1000 grams (g) EQUALS 1 kilogram (kg)
1 kilogram (kg) EQUALS 2.2046 pounds
1 ounce EQUALS 28.35 grams
1 pound EQUALS 0.4536 kilograms
1 pound EQUALS 16 ounces
16 ounces EQUALS 453.6 grams
1000 milliliters (mL) EQUALS 1 liter (L)
1 liter (L) EQUALS 1.0567 quarts liquid
1 quart liquid EQUALS 0.9463 liter
4 quarts EQUALS 1 gallon
Jun 28, 2014 | Health & Beauty
Grams to pounds
One avoirdupois pound is 453.59237 grams. One troy pound is 373.2417216 grams.
May 13, 2014 | Seca 345 Digital Scale for Babies and...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
RC Airplane Sportsman Corby Starlet Giant Scale Plane Logo
280 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
