Question about Poulan "Poulan" Push Mower
Can't find oil plug on poulan pro 550 mower - Poulan "Poulan" Push Mower
5 Suggested Answers
heres2maine
  • 84 Answers
SOURCE: how to change oil in poulan pro 650 series model
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
Posted on Apr 15, 2010
  • 5 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
trouble shooting tips: oil is too full
fuel jet and float are plugged
spark plug lead wire may be damaged inside and needs to be replaced.
Posted on May 02, 2009
  • 302 Answers
SOURCE: where are the oil drain plugs for a poulan pro 550
under the deck above the blade. It is probably a square head pipe plug
Posted on Oct 17, 2009
RonInFla
  • 86 Answers
SOURCE: My Poulan self propelled lawn mower model
where is the oil on under there ??if it's on the shaft where the blade attaches the the oil seal is bad...that's caused by old oil, which is too thin and seeps out...try changing the oil first...
this will help...copy & paste...
http://www.youtube.com/watch?v=XXvsdWbW5D8
Posted on Apr 18, 2010
What is the proper spark plug size for poulan pro 550 series
Go by the numbers on the original plug. The gap should always be set at 0.30.
May 24, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
there is a plug on the bottom of the mower above the blade but its easier to tip the mower on its side and drain it threw the dip stick hole
Apr 01, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
How to change the oil in my 550 self propelled push mower. Where is the oil plug? How often does the spark plug need to be changed. We've had ours nearly 2 years with lite use, and no maintenance.
There is no drain plug on that model , one has to lift up the entire machine ,tilt and drain the oil out of the filler spout. Change plug once a year - Champion# J19LM
Sep 10, 2011 | Poulan Pro " Pro" Self Propelled Mower
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a poulan pro 550 Briggs and Stratton Lawn Mower. I need to find theOil Realease Button
tilt the mower down by the handle, and underneath on the bottom of the motor you will find a drain plug. it has a 3/8 square hole in it. This is the oil drain plug.
Sep 24, 2010 | Poulan "Poulan" Push Mower
Where are the oil drain plugs for a poulan pro 550 model
Oct 17, 2009 | Poulan Pro " Pro" Self Propelled Mower
I have a Poulan PRO 550 series that I just bought 4 weeks ago. It won't start. The oil is at a good level. There is plenty of gas. Everything was checked and it still won't start. I am so disappointed. Has...
There are several possibilities for not starting. Water in the gas, Carburetor jet clogged ; Spark plug needs replacing, air filter needs replacing, or you have old gas. Or if you have hit something the flywheel key may be sheared. Hope this helps.
Good day.
Oct 16, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Oct 04, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan "Poulan" Push Mower Logo
1,131 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
