Question about RCA DRC8335
I've had a number of vcrs and vcr/dvd players over the years. But for some reason, I cannot set up this machine. I set up all of the cables exactly like I always have and the way that is instructed, but I cannot get the setup screen to show on the TV -- I tried this on two different televisions without cable boxes. (Oddly, this is the only machine I've ever had that does not have a designation on the back whether you want to view this on channel 3 or 4. There is no designation at all). Any ideas? It's very frustrating, including the 3 hours on the phone to Curtis, with no answer. Thanks.
  • RCA Master
  • 5,167 Answers
These days the video input channel depends on the TV and any other equipment in the sequence. I've seen component video come in as Line, Channel 3/4 (with a switch on the video device), Aux1, Ex1, AV1, Channel 60 (I think that may be specific to satellite dish receivers). If the remote has an input button, try that (alternatively, look in the menu for source options). One thing to try: press the PSCAN button on the DVD remote (to toggle off the Progressive scan).
On some TVs the channel for the video is reached by going down from Channel 2 (this works when no channels are programmed into memory and the intervening channels are skipped).
What TV are you connecting to the DVD/VCR player? (If it is an older TV and any external device was connected to either channel 3 or 4, check that the TV works with any input device. I had a 19 year old TV (coax in only) that was damaged and no external device worked.)
I wish that I could be of more help.
Posted on Apr 26, 2010
Also press the PSCAN button on your remote and make sure it is set to "OFF".
Posted on May 16, 2010
Codes for oneforall
It is my pleasure to guide you.
Look through these. I hope what you need is here.
Manufacturer's Codes
Setup Codes For Cable Boxes
Setup Codes For Cable Box/PVR (or DVR) Combos
Setup Codes For DVD Players
Setup Codes For DVD Player/VCR Combos
Setup Codes For PVRs (or DVRs)
Setup Codes For Satellite Receivers
Setup Codes For Satellite Receiver/PVR (or DVR) Combos
Setup Codes For TVs
Setup Codes For TV/DVD Player Combos
Setup Codes For TV/VCR Combos
Setup Codes For TV/VCR/DVD Player Combos
Setup Codes For VCRs
Please post back which one is yours with Serial number and Mfg.
Setup Codes for DVD Players such as Magnavox 0503, 0539, 0646, 0675, 0821,1268
Jun 05, 2011 | One For All URC4220 Remote Control
VCS422. The VHS will play with a tape, but not from the TV. The display just as four horizontal dashes. Thanks.
I would suggest you replace your AV cables.
After a few years the cables can go bad.
If this doesn't fix the issue, try playing the tape in another VCR.
If that works, it's probably time to replace your VCR with a VCR/DVD combo player.
Mar 13, 2011 | Zenith VCS442 VHS VCR
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
Can get dvd/vcr to work but vcr won't record
first did you program the vcr to match your cable channels ...that needs to be done on most vcrs/dvd/ combos and second if you have a cable box on your tv you still need to run a coax cable from the cable box to the in of the dvd player and out of the dvd player to the tv.
May 14, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR will not turn on.
Remove top cover of the VCR. Then look near the back where the plug-in and power supply is. There should be a little glass fuse. You should keep that fuse and take it to the store and replace it with same exact one. If your VCR can be self-repaired, than this is the only thing you can try.
Mar 11, 2009 | Philips Televison & Video
Lost manual, can't get VCR to play
There are several Philips and Magnavox DVD/VCR combos that have sepearate video connectors for the DVD and VCR side. Double-check the yellow composite cable that is plugged into the back of your Magnavox - it should be plugged into an area that says either "DVD/VCR" or "VCR". If you are currently using red, green, and blue video cables, you will need to add a second video cable - a yellow composite would be easiest. The reason for this change is that red/green/blue cables will only operate the DVD side on most Philips/Magnavox players - that is just the way they decided to design them. If you happen to find a model number listed on the back of your combo unit, and have the model number of your television, I can take a second look at it, and tell you exactly which connections to make. Good luck!
-Tha Mp3 Doctor
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting my tv to cable,vcr and dvd
what is the problem not enough connection areas usually you would connect your VCR to your cable box and set channel three on your cable box for the VCR then using one of your other inputs from your TV for the dvd player . Is your DVD player HDMI or Componet?
Dec 28, 2008 | Televison & Video
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
RCA DRC8335 Logo
434 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
