Question about SanDisk Sansa e260 MP3 Player
Sansa broke i have a problem with my sansa e260 its able to turn on but when it does a message comes up that says : "not enough space for music DB. Please remove 6 mb of storage" no when i tried to connect it to my pc and remove some music i couldn't. in fact i couldn't even find the music cause there was no music folder in the player that was showing up. but when i check on wmp it shows i only have 30 mb of memory left... am i totally screwed?
  • pricebob18 Sep 11, 2008
    in fact i couldn't even find the music cause there was no music folder in the player that was showing up. HELP!
This solution come from Sans tech support (it helped me):
Lets format your player, formatting your player will erase all the content off your player but will bring your player back to factory settings.
To Format player:
1. Under the main menu go to Settings> USB(Mode)>MSC(Rhapsody).(If you do not see a USB mode, you have a version 2 player. Follow the second format instructions below.)
2. Connect player to computer.
3. Open My Computer.
4. Under devices with removable storage you should see your player.
5. Right-click on the players drive and select format.
6. Make sure the format type is FAT 32 and select start.
7. Select OK when the warning screen comes up and the player will begin to format.
To format the player, please follow the instructions below:
1. Turn your player on.
2. Go to the settings menu.
3. Select format.
4. Select yes to confirm the format.
Please feel free to contact us at anytime via email or by phone at (866)726-3475 Eastern Time 7AM - 1AM
Open 7 days a week, except for major Holidays.
Posted on Jul 30, 2008
I have two solutions. First, choose a song and start playing it and then try to delete the song later. If you can't choose a song, try my other solution. This might not work but it's worth a shot. Do you have windows or a mac because this solution is for windows. Download the newest firmware version for your sandisk at http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Click on download sansa firmware updater and install it. After you have installed it, plug your E260 in. After a couple of seconds, an icon should pop up on the toolbar in the bottom right corner. Check the boxes and then install it to your E260. When it is finished installing, unplug your player and it will shut off after about 10 or 15 seconds. Turn it on and go to settings. Choose USB mode and look at the mode that it is currently on. Choose a different mode and plug it into your computer. Look through the folders and try to find music that you can get rid of. Try all 3 modes to find the music folder. I hope that it works for you. Otherwise, just ask Sandisk.
Posted on Mar 24, 2008
When i turn the player on it says Not enough space for music DB Please free 6 MB. But it says in the info Memory 0MB and Free 0MB
Connect to your computer copy music to a folder and save as whatever name you give it Then format Check the folder with the music in it to see if there is a file thats not MP3 delete it if there is one then replace the musicto the sansa keep about 6MB of free space
Dec 23, 2010 | SanDisk Sansa e260 MP3 Player
I cant turn on my sansa
you need to free space so it can use the firmware
Jun 17, 2009 | SanDisk Sansa e260 MP3 Player
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
I kept syncn music to my sansa mp3 and now it wont play.
Apr 12, 2009 | SanDisk Sansa e260 MP3 Player
Sansa m230
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
Sep 07, 2008 | SanDisk Sansa m230 MP3 Player
My sansa e260 isnt turning on
Well for starters, clear some memory. It sounds like the player is trying to turn on but failing as there is not enough free flash memory for it to use in a RAM like fashion. If youre using windows enable the view of hidden files folders. [Start> Control Panel> Appearence and Themes>Folder Options then browse through the tabs until you find a list which has the option "show hidden files and folders". Then plug in your e260 and go into the larger removeable drive. Then go into the folder "VIDEO" or "PICTURES" or "MUSIC and delete some files. Then once you have deleted at least 100MB, unplug and restart the player. This should fix your problem if it doesnt. Consider formatting the removeable disc, or updating the firmware. [However take extreme caution with formatting the disk to ensure that it does not contain the program files needed to run the player.
Dec 31, 2007 | SanDisk Sansa e260 MP3 Player
I lost my free space@!!!
The error message says, please free up 6MB for Music DB (database).
Connect the device to your computer and remove several songs. Restart the device, and you should be back to normal.
Best of Luck.
Oct 13, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
90 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
