Question about Frigidaire Dryers
Frigidaire model FEQ221CAS2 Thumps every 1/3 revolution. Sound from behind the heat guard. How to fix?
My new sold f80 thumps when it runs, 2 thumps per revolution
Need LUBE or wax, see your owner manual, and Do it right now. use 100% silicones LUBe.
2) Lube the rollers bearint use WD-40 for rollers bearing only.
God bless you
Nov 14, 2012 | RTO Sole F80 Treadmill
The dryer sounds like an unbalanced washer. Sound is coming from the front top left side. Machine diesn't move. does it even when empty. Began after was on for about 10 minutes.
Possible bad bearing for the drum front or maybe a drive belt with a missing segment that thumps with every revolution. You will need to open the top to inspect--either screws in the back edge of the top or insert a thin putty knife into the front corners to release a spring catch on each side. Hope this helps!
Oct 09, 2010 | Frigidaire GLEQ332A Electric Dryer
My dryer thumps as it turns. What may need fixed/
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 05, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Control knob hangs
Timer has small gear pull panel off and see if gears are stripped in one spot meaning no teeth on the gears
Aug 24, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire dryer feq221cas2 the startswitch will not stay on
The switch is bad and need to be replaced. Holding the switch in the on position may cause it to burn, thus causing a fire so please do not hold it in manually.
Jul 22, 2009 | Dryers
My new dryer thumps every revolution
Flat spots on the support rollers from sitting in storage will make a thump. So will heavy wet clothes if they are not spun dry enough from the washer. This may lessen as the unit is used but since it is in warranty a service call to rule out major problems is in order.
Eric
Jun 17, 2009 | Maytag MDE9206 Dryer
MICROWAVE OVEN DOES NOT HEAT ALL OTHER FUNCTIONS WORK
Since the light comes on and the turntable rotates, I would suspect a bad magnetron, a loose connection at the magnetron, a failed high voltage transformer, or shorted high voltage rectifier diode.
If it's less than one year old, it should be fully covered under warranty.I'd suggest contacting the manufacturer to get it fixed free.
Ifit's within the magnetron portion of the warranty (usually 5-9 years)but out of the original full warranty (usually 1 year), then yourmanufacturer will cover the part cost, but not the cost to visit you orthe labor charge to do the work.
If you or a friend want to work on it, please see these links first:http://www.microwavedisplay.com/safety.txt& http://www.microwavedisplay.com/disassembly.txt
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
For Frigidaire models, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Or you can find your nearest Frigidaire/Maytag-authorized servicer here.
You can visit Daewoo onlineor call them at 1-800-323-9668 or 1-800-553-4355 to find parts or findyour nearest authorized service center to have them do the work.
Oct 05, 2008 | Microwave Ovens
Wont spin
many possibilities you may need chat help
May 07, 2008 | Frigidaire FDE336RE Dryer
Ok final Question
If this is a frigidaire, when the washer has a load in it, as the agitator agitates the tub should move about 1/8 of a turn. Meaning that for 8 agitations the tub should make 1 revolution. We call this indexing in the appliance repair world. If the tub is making 1 revolution in 4 agatations or 1 revolution in 1 agitation, the transmission is bad. This should have a 5 year warranty if purchased before 2006. You will also need a tub seal. Hope this helps
Feb 13, 2008 | Frigidaire FEX831CS Top Load Stacked...
Thumping sound at the end of spin cycle.
Rankine, sounds more like a worn drive block that sits under the basket. Usually the brake will not make a thumping sound. Attached is a couple of pictures. Check this out first...Catriver..post back.
Jan 16, 2007 | Kenmore 24852 Top Load Washer
Dryers Logo
55 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
