Hoover 550 MA Top Loading Washing Machine
My machine is about ten years old and I cannot find my operating instructions.
It recently stopped agitating during the wash or rinse cycles.
It still spins and drains but will not wash.
Does this model have a belt that might need to be replaced and if it does how can I find the belt on the machine to check?
  • Anonymous May 23, 2008
    My machine spin but when it comes to pumping water out it seems pump does not work.
    Any solution?
    Ali
  • NAOMISEAN Jun 29, 2008
    MY HOOVER 550 WASHING MACHINE WONT SOAK AND FILL UP WITH WATER AND WASH BUT IF YOU PUT IN ON SPIN IT WORKS FINE
I have 550 Hoover about 6 years old,just out of warranty period,
is currently noticed the problem of stopping during prewash rinse, start again it startsup but stopped immediately.And keep repeating it. If i skip to spin manually then it almost completes the cycle. THis problem starts few months back also then vanished by itself and now it starts again.can some guru tell me if its because of belt or drive belt etc.
Posted on Apr 28, 2008
    Sergeant:
  • 351 Answers
If if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Posted on Mar 26, 2008
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
My 7 year old GE top loading washing machine stopped agitating or spinning. Water runs and drains.... I ran a blanket in it yesterday and suddenly today it does not work....
I assume drum does not turn. Check drive belt as it maybe broken. If belt is o.k check if motor is burnt out, if not could be problem with electronics.
Jan 15, 2011 | Washing Machines
Does the hoover 200m 4.4kg top loading washing machine have a lint filter if so where is it
Hi just read your posting.It should be in the center of the agitator.Pull the center out and there should be a lint bag attached to it.Unfortunately they do not stop much lint from getting on the clothes.Hope this helps and please reply if you need more help.
Jun 17, 2010 | Hoover HTC243 Top Load Washer
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Hoover 500 ma top load washing machine manual & specifications
FRIEND,
BUY SPEED QUEEN FRONT LOADER. IT ONLY USES 13.9 GALLONS OF WATER PER WASH!!!!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 26, 2008 | Hoover Washing Machines
Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Aug 26, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
1,514 people viewed this question
Top Washing Machines Experts
