Question about Caroma 270W-RF Reflection Round Front Dual Flush Toilet - White
How do i remove the lid on my modern style toilet cystern
  • 9 Answers
Your lid should have two PVC or Nylon screws on the underside. Twist them off and pull off your seat. They may be excessively tight to keep the side from sliding from side-to-side, so be prepared with a pair of Channel-Locks to get in there and break them loose.
Chris
Posted on Apr 28, 2010
Water level in new toilet bowl to low
water level in the bowl( pan) is determined by the height of the sewerage pipe level that it is connected to and is fixed by design and style of the pan
unless you are on about the water level in the cistern( tank) which you can adjust yourself
Nov 17, 2015 | VitrA Aria Toilet with Elongated Bowl/...
I have just bought and installed the newbury close couple tiolet but when i flush it there is water leaking from the bottom of the cistern, but it only happens when i flush it any hlp would be great.
You need the proper wax ring to seal the toilet to the flange. Remove the toilet and check the wax ring. If it isn't compressed, get a spacer and a thicker ring.
Dec 05, 2014 | Home
I have Kohler toilet ...I believe it was a Rialto model....the numbers inside the tank are T33 K2402P3 ...
picture is of a kohler rialto
looks like you can get the parts or retro fit newer kohler flush parts
ring around for a plumber or kohler toilets seller that can supply kohler cystern parts
Apr 28, 2017 | Home
Need to remove lid on cystern
Hi im Rossouw
It depends on the kind of cystern u have. here is a few i know how to remove
1.The 2 button setting on top of cestern needs to be turned left untill it loosens up
2.The 2 screws at back of cystern lid needs to be unscrewd
3.also a 2 button cystern. has metel cabel under lid. can lift lid a littel. thast pull hard on cabel were it enters the 2 flush button meganisem
If not 1 of the above plz let me know and i will help u therder, dose are the most commen problem 1ns
plz vote 4 my advice thx
Jul 17, 2010 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
The toilet is a Trebol San Jose dual flush,,,,it just seems to use more water than I would have thought. I was wondering if there are adjustments that can be made to the mechanism to use less water
HI im Rossouw
On the side of the cystern u will see the inlet velve with a flowting device conected to it, the flowting device needs to be udjusted. Exstend the arm of the flowting device more for less water and retracked for less
Hope i helped plz rate my advice thanx
Jun 26, 2010 | Home
All of a sudden it won't flush, little resavoir in take empties but water in tank doesn't
The Problem can be fixed by fixing a new flush meganisum to your cystern, sound like the old flush rubber is stuck in the cloused posision, have a look by taking the meganisem of, if so replace it .
Jun 11, 2010 | Eljer & Patriot& Toilet Tank With Lid
Toilet seat come loose and no obvious way to tighten??
well there should be 2 hinges rite behind seat. you wont see the screws cause they are under a plastic cover. take a flat head screw driver and pry up cover. lil cover should lift up towards tank. then you should see screws. the nut is under bowl you have to bend down then look up to see them or do what i do and feel for them. take big flat head or big philips screw driver and while you hold nut titen screw. hope this helps. duane:)
Oct 05, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Leaking cystern
turn water off flush scoop out water remove 2 screws on side of toilet lift toilet off clean replace wax ring reinstall
Jan 21, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Caroma 270W-RF  Reflection Round Front Dual Flush Toilet - White Logo
435 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
