Question about Yamaha RX-V2500 Receiver
IPod connected to V-AUX front input on RX-V800 plays fine in room 2 connected into the AUX input on a Yamaha HTR-5830. I can't get any other sources from the RX-V800 to play in room 2. My cable runs from the Zone 2 out of the RX-V800 to the AUX input on the HTR-5830. I have the input setting on the HTR-5830 set to AUX, A speakers on, volume up. Ipod plays fine.
SOURCE: yamaha htr-5830
I own this receiver, and 18db is damn loud. Granted - your room might be significantly larger than mine with your speakers spread much further apart, or your speakers might be much less efficient than mine (this means that they want more power than the receiver can dish out - I have whatever speakers came with the "YAMAHA Home Theater in a Box" [the model that came with the HTR-5830]), but I'm pretty sure that the receiver doesn't get any louder (or at least not much). My suggestion is to turn down the volume to about -20db and work up from there after the movie has started. It might be easier to test the volume using music. The negative sign is deceiving - I rarely bring mine up to 0db. Also check the resistance - there's a red switch on the back of the receiver that switches between 6 and 8 ohms - make sure that it matches your speakers' resistance. If turning down the volume doesn't work, then post the problem again. Hope This Helps.
Posted on Nov 07, 2006
SOURCE: Rx-v800 shuts off after few seconds
Hi, You should try to see, on main board, the ground G2(TP00385), just to make sure if the screw is too tight. Its location on Schematic Diagram (Main) is E8. All the best, Rasgador
Posted on Sep 17, 2007
SOURCE: Yamaha RX-V800 Remote Control
Change the batteries
Posted on Nov 13, 2007
  • 236 Answers
SOURCE: Yamaha RX-V 800
Go to yamaha service direct they should have the parts. impossible for this model to be phased out. this is a model about 6 years ago only. they still have the parts for that. Power output and driver transistors are industry standard, replaceable too byt other newer model. you just need to find a real good techie for yamaha... i mean yamaha expert
Posted on Mar 19, 2008
Marcos_Ce
  • 71 Answers
SOURCE: yamaha htr 5930
I think you have to adjust balance.
Page 22 of user's manual explains how to do it:
Posted on Nov 23, 2008
How to connect a turntable connected to a yamaha a450 stereo amplifier...can I attache the a450 to the htr-6130 ?
If the turntable is newer kind you can connect it in any Stereo input like CD, VCR , etc.
If the turntable is older model you can only connect it to PHONO input (if amp has one) and make sure earthing cable is connected on Amp
Remember input is only stereo (unless your model has digital input) and select sound effect eg Pro Logic for enhanced sound,
Aug 26, 2014 | Yamaha HTR-6130 Receiver
Having trouble connecting a ipod to the back of the reciever with rca cables. I plugged in to the V-AUX and also put the input to AUX on the reciever. still no sound
I think the V-AUX is a video input, not audio. Look for a red and a white RCA female input to connect the cable. Those represent the right and left, respectively, audio.
Dec 31, 2010 | Yamaha HTR-5830 Receiver
Yamaha HTR-5830 does not work with Sony PS3 optical cable connection. There is no sound at all. Do I need an HDMI cable. Right now I only have component cables which work fine with the red and white...
Make sure you have the "audio input mode" on "Auto" it's a small button on the front of the Yamaha. Then go into the PS3's Audio setup and make sure it's set to Digital. Hope this helps
Jun 04, 2010 | Yamaha HTR-5830 Receiver
I am trying to hook up my Yamaha Universal Dock YDS-11 for my iPod touch into my Yamaha HTR 5830 Amp but there is not where to plug it into. Do I need another type of cables to do this.
Hi, I'm afraid that your receiver doesn't support YDS-11. You can check it at yamaha site. This dock uses special cable and special connector on the receiver (which yours doesn't have).
So the only way to connect your iPod to receiver is via analog audio output (jack connector on the iPod).
Jan 29, 2010 | Yamaha HTR-5830 Receiver
I have a Yamaha HTR-5630 receiver. Can I add a
try use 1/4" stereo plug to two RCA plugs used with amplifiers and mixers
[img]http://www.mcmelectronics.com/images/product/icons/magnifier250.gif[/img]
use yamaha cd or aux input ..
Dec 31, 2009 | Yamaha HTR-5630 Receiver
Rx-v800, have a problem when i swtich the input mode, it will turn off. after leave it for few months, now no problem but not sound.
Test an audio source like "DVD" connected to the "Direct" input with left,center,right,rear,andsub input. put the receiver in "Direct mode" if you get audio, the main DSP chip is bad, get an estimate first since it can only be verified by bench testing the unit. It's not a cheap repair 400-500 range. Most new Yamaha receiver's in the modest range run 500-800- new. Hope this helps
Nov 08, 2009 | Yamaha RX-V800 Receiver
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
No picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Mar 19, 2009 | Yamaha RX-V800 Receiver
Yamaha RX V800 w/ iTunes Airport Express
thats cause your patch cable is mono get a stereo 3 ring connector.
Apr 01, 2008 | Yamaha RX-V800 Receiver
Open Questions:
See all Yamaha RX-V2500 Receiver Questions
Yamaha RX-V2500 Receiver Logo
117 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
