Question about Sony KLV-S19A10 19 in. HDTV-Ready LCD Television
Need a desk top stand like in the picture.
I have a klv-s19a10 and i have a wall bracket. The problem is i would like a desk top stand to stick on top of my current tv stand.
4 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
  • 102 Answers
SOURCE: i need a table top tv stand for my sony kdl
hi here is a link to the stand for your tv at sony parts store >
http://www.partstore.com/Part/Sony/Sony/KDL40W3000/Sony/Sony/A1257997A/New.aspx
please dont forget to rate me i need a few more for my badge thank you and if you need anymore help let me know..
Posted on Feb 04, 2010
DigitalPlus1
  • 105 Answers
SOURCE: I need to get a
As you have probably found out already, getting one at a local retailer isn't going to be likely. You may be able to get one from Sony, but it could cost you hundreds of $$. Ebay and Craigslist may be your best friend for this. Someone may be parting out a TV that doesn't work or they wall mounted and are trying to sell the stand. Be careful though as the stands are model specific. Make sure it came off the EXACT same model TV. Another source is on line parts sellers. Google "TV parts" or something similar. I've used ShopJimmy.com but there are many out there.
Posted on Jun 10, 2011
SOURCE: I have a Sony Bravia KDL32S3000 and need a table top stand!
Hi, i have a sony bravia KDL 32S3000 and we want to take it down from the wall but have lost the stand, does anyone know where i can get a new on?
Posted on Jul 14, 2011
How do you take a stand off
There are 4 screws found in the center bottom of rear plastic back. 2 at top and 2 at bottom - approx 1/2 inch from bottom the 1st 2 will be about 3 inches apart - then directly above there are 2 more. These screws hold the bracket that holds the stand. Once you remove the bracket there should be no parts sticking out further than the actual television and can now be mounted to the wall with a mounting system.
Jul 20, 2014 | LG 42LH30 42 in. LCD TV
Can the monitor height be adjusted. It seems to be fixed to the stand with no adjustments?
No but you could always put something under the stand most can only be tilted for lighting reasons.
Jul 04, 2011 | Princeton Digital VL1916 19" LCD Monitor
I need to get a replacement table top stand for KLV-40U100M
Jun 10, 2011 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
What is the remote code for this tv Sony KLV-S32lA10
Hello
Programmable code number for DVD/VCR [Sony] is _ 601 (Sony Dream System)
Programmable code for SAT/CABLE is _ 801 (Sony Satellite Receiver)
Above stated both codes are common for [SONY KLV-S19A10 _ KLV-S26A10 - KLV-S23A10 AND KLV-S32A10 compactable]. OK.
Feb 24, 2011 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
Hi I have been given a plasma tv Relisys
http://www.mountright.com/desk-mount-desk-bracket-for-1422-lcd-tv-swivel-1406-21r-p-27.html
I found this site and it has a desk mount bracket for your tv.
Relisys has gone into administration so getting the origional stand could be difficult.
I hope this helps
May 08, 2010 | Televison & Video
How to connect compaq presario v2000 to sony klv s19a10
Go to network wiz. Know computers name and follow wiz
Dec 06, 2009 | HP Compaq Presario V2000 Notebook
Audio distortion on VHF/UHF 75 ohm input
Please try the steps provided below and check if that helps.
Press the WEGA GATE on the Remote Control.
Then, select the SETTINGS option in the Menu.
Then, select the AUDIO Settings.
Then, set the STEADY SOUND option under the Audio Settings to AUTO.
Also try changing the MTS Setttings under the Audio Settings.
Jun 15, 2009 | Sony KLV-S19A10 19 in. HDTV-Ready LCD...
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email bammbamm@ptd.net if you want pictures and costs
Mar 05, 2009 | Acer AL2017 20" LCD Monitor
Sony KLV-S19A10 19 in. HDTV-Ready LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
