Question about Magic Chef Microwave Ovens
When oven is turned on an temp. is set the oven will go to proper temp. However, when you open oven door to put food in the temp. drops considerably. This causes food to under cook. What can cause problem????
  • robert downer sr Apr 26, 2010
    Looking for solving problem on GAS STOVE/OVEN
    President:
  • 803 Answers
Turn the temp up a few more degrees to compensate for when you open the door there really is no way to fix this its just common sence that says when a door is opened the heat will come out
Posted on Apr 26, 2010
    Brigadier General:
  • 3,917 Answers
Thanks for writing to Fixya.com.
Control system for a microwave oven or a combination microwave and convection oven where the on time of a microwave generating system is decreased while convection heater on time may optionally be increased as a food product cooks to a predetermined, desired temperature. A temperature probe inserted in the product senses temperature and connects to a Wheatstone bridge. A differential amplifier connects to the Wheatstone bridge, an up/down integrator circuit connects to the differential amplifier, and a comparator connects to the integrator and which includes a latch to generate a signal to control a triac for controlling the microwave generating system and to provide a closed loop feedback signal to the temperature probe. The control system starts the oven cooking with substantially one-hundred percent power and, as the desired predetermined temperature is reached, the microwave power level is decreased through the control system. As the microwave power level is decreased, the average power to the convection heater may optionally be increased to speed the browning and crisping of a food product. The control system, through the electrical circuit, converts the temperature differential signal into a microwave generating system level signal. The closed loop feedback signal is generated by the microwave generating system which is controlled by the comparator latch and an NPN transistor controlling the up/down integrator. The control system can be used with any type of microwave oven.
Thanks for contacting Fixya and please accept the solution if it has helped you.
The fan comes on when I first open the door to put food in the mircoware.
The fan always comes on when you open the microwave door, to either put food in or take foods out. The oven doesn't know so it does both.
The fan removes condensation, steam and cooking smells.
Nov 11, 2015 | In Microwave Ovens
Microwave starts on its own when microwave door opens.
see this adjustments. God bless Oherwise the main control board can be defective.
Oct 03, 2012 | GE Microwave Ovens
Preheat a oven
preheating gives u prepare temperature of oven for some specific cooking
Don't leave the oven door open too long when putting the food in because the temperature will drop a little but that is not horrible and shouldn't be a cause of great concern. Each time you open the oven door the temperature will drop a little.
May 19, 2012 | Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
My new panasonic microwave model NN ST 340w has the internal light on when I heat up food. However when I open the door to put food in or take it out, the internal light does not turn on. What can I do?...
Your oven light is busted or damaged. You can buy the replace at the any electronic shop. Just open the top cover then you will see the light you will going to replace
Aug 15, 2011 | Panasonic NN-H664 Microwave Oven
I hope someone can help me. I have a Whirlpool Fridge Model Number WRN52HWG6 and we bought it from Fridge and Freezer City O'Connor Perth about 6 months ago and I don't have the owners manual for it...
If you turn the dial clockwise this will make it colder anticlock less cooler...Start by switching off for a few Hours leave door open to allow defrost...Turn the stat fully anticlockwise to almost off then put it to say 2 o clock position assumming that it will go from 12 to 10,this should allow food to remain cold without freezing.you are looking for about 3/8 Degrees c.....Buy a cheap thermometer this will help to keep you on the right track..Good luck
Mar 07, 2011 | Whirlpool Microwave Ovens
My GE Profile JE1390 (Sensor Convection Microwave Oven) is coming on when the door is opened. It will still work once you put food inside and set the timer, but you risk radiating yourself. What might...
Door switches
If one of the door interlock switches is not switching properly or there is a condensation problem on the sensor control panel, either can cause the turntable/light/oven to come on even though the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Jan 19, 2011 | GE JE1390 Microwave Oven
Microwave Ovens Logo
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
