Question about Haier HLH406BB 40 in. LCD HDTV
Sound fine with HDMI input and DVD input. No sound with TV input. Mute is not engaged on either TV or Cable remote. Solutions anyone? Thanks
  • Haier Master
  • 8,457 Answers
Unplug the tv about an hour,replug it back in,now ur tv it resetting it back to factory setting.Go into the tv menu,go into the AUDIO setting.Go down to reset,press it,now ur Tuner board it resetting,the sound should come back an work now.Not then ur Tuner board it defective,must be replaced.
Posted on May 14, 2010
My Insignia Blu-ray DVD player and our Panasonic DVD player are playing only the sound with no picture. We put the correct imputs on the TV. They were playing fine a few days ago. We have Charter cable....
Sounds like the input board on the tv fried. (45-65$ fix if that's it)
Try the same two devices on different inputs , ie change from hdmi to component , or just use hdmi 2 instead of one, you get the idea.
Make sure the devices dont work on other inputs on the tv.
Then take a different device , like a 3rd dvd player and try it.
If nothing works in that input but works in other inputs the tv input board might (likely) need replacing.
If the third fresh device does work in that input , it is both dvd players or the cable you are using. (try to use a different cable in the tests than the one you have already used. )
Feb 13, 2018 | Zenith DVB312 DVD Player
How do I hook up my surround sound system thru my stereo and tv
connecting your surround sound system is not complicated.things you may need:OLDER STEREO SURROUND SOUND:analog red, white, and yellow cable connectorsHDMIaudio fiber opticsif you bought your stuff new from electronics store,then it would be easier.all you need is HDMI cables (mostly)depending where your inputs and outputs go, you must know the rule. OUT-TO-IN. that means if you are using a cable box, dvd, bluray, playstation, or xbox. everything in these electronic devices are OUT. then connect them to the IN ports of your surround sound. at the back of your surround sound there will be connections saying IN-dvd, IN-dvr etc. connect your OUT DEVICES.
NOTE: YOU MUST KNOW WHAT ARE YOUR CONNECTIONS, LIKE DVD-IN OR DVR-IN CU'Z YOU WILL USE YOUR REMOTE TO CHOSE WHICH CONNECTIONS YOU WANT TO USE.
now from your surround sound to your tv.the same ruleout to in of your tv. You should look for HDMI port that is saying OUT. you will connect your HDMI cable from there connecting to your IN of your tv. remember which port you plugged the HDMI cable as you will switch to that particular input. it will say at the back of your tv in-1, in-2, in-3 or as much as the manufacturer want to have in there product.
connecting your speakers.you must remember the color code.if you chose red as positive, all the red wire must be positive.colour may be different but same idea. if you have sub-woofer it will be an analog cable you will only use single cable. At the back of your surround sound there's a connection saying sub-woofer out.
now selecting your inputs.turn on your tv and stereo.newer tvs and stereos are smart they can configure there system which is turned on.
anyways if you will do it manually, you must select from the remote what is the connected input. (input 1, input 2 etc.) if you found the right input, do the players (dvr, cable box, dvd, bluray, playstation, xbox etc) turn them all on and select from your stereo remote control.note all the inputs you selected.
Dec 31, 2012 | Televison & Video
We have an LG 32LX2R-ZE. We have no sound, but the picture (Virgin Cable) connection is fine as is our Internet. I've checked all the leads and, no, neither the TV or the Virgin box are on mute!. Any...
I had the same problem and after buying loads of different cables came to the conclusion that the HDMI input on the TV was at fault. Bit of a sledgehammer to crack a nut but I upgraded my home cinema amp to one that had HDMI in/out and now I put the sound through that and use the TV as a panel with volume turned to zero.
Jan 13, 2011 | LG Televison & Video
Sometimes Loses Sound
disconnect the hdmi cable from both ends it resets the sound signal!!!
May 06, 2010 | Samsung HP-T4254 42 in. Plasma Television
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
NO SOUND ON TV. CABLE REMOTE AND TV REMOTES HAVE THE MUTE OFF. TRIED WATCHING DVD, WORKS FINE WITH SOUND, THEN BACK TO CABLE, NO-SOUND. PLEASE HELP! TV IS SAMSUNG
You have just performed the best way to troubleshoot this kind of problem. Check all cables on the back of the tv and your sources and look for any loose or disconnected cables. Next, Hook your DVD palyer to the SAME input that you are using for the cable box. Now if you have good pix and sound then you have a bad cable box. If not then you have a bad Main bd in the tv.
Jun 30, 2009 | Samsung LN37A530 37 in. LCD HDTV
No picture, can't set inputs on TV
try tighting the screws on the inverter. they sometimes get loose and then you lose the grounding.
Apr 20, 2009 | Televison & Video
42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Feb 15, 2009 | LG 42LG50 42 in. LCD HDTV
X2Gen MV37R Flat Panel TV Sound & Universal Remote
check to see if another major brand produced the tv, like lg produces westinghouse stuff, and see if the other brand works
Nov 14, 2007 | Televison & Video
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Oct 02, 2007 | Sony Playstation 3 (PS3) Console
Haier HLH406BB 40 in. LCD HDTV Logo
156 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
