Question about Magic Chef CDB6100 Built-in Dishwasher
Dishwasher Not Cleaning Dishes
Dishwasher sounds like it is running, but it is not cleaning the dishes. Soap dispenser not opening, tried filling dispenser 1/2 way & 3/4 way so as not to have it stick. The probelm is getting progressivly worse it wa cleaning a little now not at all.
  • Magic Chef Master
  • 43,501 Answers
Dishes aren't cleaning. Filling with water, rinsing then draining, refilling with water -- hot, soap released. When dishes come out, barely clean. Used to work like a charm... Thoughts?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 16, 2011 | Miele 23 in. Novotronic G841 Built-In...
Dishes do not clean, although the water is hot and the soap dispenses. Dishes and glasses have a cloudy residue at times, and dishes sometimes have small food particles baked onto the surfaces.
Hi
Feb 13, 2011 | Bosch Dishwashers
The dishwasher is not cleaning my dishes very well and the soap dispenser doesnot open t let the soap out to wash the dishes
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 09, 2011 | Estate 24 in. TUD5700KQ / TUD5700KB...
Dishes not geting cleaned. Soap is left in the door dispenser only partially used.
Hi
Daniel
Dec 13, 2010 | Maytag Dishwashers
My dishwasher is not cleaning my dishes. at the end of the cycle there is still liquid in the dispenser.
Hi
Daniel
Dec 13, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Detergent is left in the dispenser cup. Dishes are not clean after going through a complete cycle.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Please post back for any further assistance.
Daniel
Aug 02, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher - soap dispenser won't open while washing dishes
A simple was motor is used to open that.
This video shows how to change a door latch but the dispencer basically does the same thing. HERE
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
I just bought a used Kenmore standalone dishwasher and ran it for the first time. The dishes on the top did not get clean and the soap did not come out of the closed soup dish. at one point I took a shower...
The inlet filter is probably clogged. Try letting it fill up. Open the door to stop it right after it starts to wash Pour a gallon or two of hot water in and see it it works better Stop and do this everytime it goes to fill up. If the door opens , soap is used and dishes are clean ,clean the filter in the fill valve and possibly replace it. or the whole valve. (around $25) The soap door may be a seperate problem. I don't remember if Kenmore uses a spring or a small heat element to open the soap dispenser. Try cleaning it really well, shut the dispenser, open the door and turn the timer very , very slowly and watch to see if the dispenser opens. (WIth the door open the dishwasher will not run, but leave it plugged in.) It should open sometime during the cycle.
Jun 29, 2008 | Dishwashers
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Magic Chef CDB6100 Built-in Dishwasher Logo
182 people viewed this question
Top Magic Chef Dishwashers Experts
240cpa
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
