Question about IBM Office Equipment & Supplies
Want to replace the driver belt of S-II
I have a IBM correcting selectric. I want to replace the driver belt.
I have the replacement belt.
How do I do this?
  • IBM Master
  • 3,594 Answers
You must remove the entire left side of the cam line and get it in in time. Not for the novice.
DickyO
Posted on Apr 27, 2010
How to replace drive belt on ibm typewriter
Not a job for the untrained. The entire L. cam line must be removed, replaced and retimed.
DickyO
Jul 10, 2014 | IBM Correcting Selectric Ii Typewriter
Recommendation for IBM Repair Company
I Googled Typewriter repair Washington DC and got 4. I have no idea what they charge.
DickyO
Apr 02, 2014 | IBM Correcting Selectric II
Broken metal wire in ibm selectric ii
You have either a broken tilt tape or rotate tape. One controls the tilting of the element (ball) and the other controls the rotation of it. If either one is broken, you will need a qualified technician to replace it and make any adjustment necessary so it doesn't break again.
Oct 17, 2013 | IBM Correcting Selectric II
The alignment of a couple of letters (i.e., "m") on by IBM Selectric II is askew. How can this be fixed?
It may be as simple as replacing the element (ball). Remove it and look for broken ao badley worn teeth on the lower edge of the ball.
DickyO
Jul 31, 2013 | IBM Correcting Selectric II
My typewriter hums but nothing happens...seems like the motor is jammed...
The humming is probably the motor turning but the drive belt may be broken. You would need a qualified technician to replace the belt if necessary.
Apr 05, 2013 | IBM Correcting Selectric Ii Typewriter
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
How do I replace the foam padding in my ibm selectric ii typewriter?
The foam was used for sound dampening. Over time, the foam falls apart and can cause problems inside the machine. If it is coming off, we usually remove it with a razor blade. New foam is not available any more. Hope that answers your question.
Sep 01, 2012 | IBM Correcting Selectric Ii Typewriter
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
265 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
