Sony projector tv kp-61v80
I have a sony tv # kp-61v80
the other night it just would not turn on
the red light on front of tv blinked 1 time and i smell something burning in the back of tv i looked and the smell and a little smoke came from a part that had these numbers on them d2578 it is a gray square small piece with 3 progs on it it has more numers on the bottom of it 9e2 can i fix this my self ?
  • Anonymous Jul 29, 2008
    same trouble with a Sony
    Scholar:
  • 87 Answers
The part is a horizontal output transistor 2SD2578. There are probably other parts shorted such as a flyback transformer and or power supply components. I would not try to fix this one if I were you. Sony TV`s rarely blow just one part. Usually you have a handful of bad parts. Sony`s can be difficult even for experienced technicians.
Posted on Mar 24, 2008
    Sergeant:
  • 247 Answers
D2578 is a transistor that often runs hot and burns out. Replace it with 2SD2539 transistor that runs much cooler. That should solve your problem.
However, if it has burnt out due to another component causing a voltage problem, it may only work temporarily or not at all.
I'd guess that the odds are 90-10 in your favor and it should not be expensive - so it is definitely worth a try.
You can get the 2SD2539 transistor from a TV parts dealer or from Sony. It does not have to be made by Sony. Parts dealers will be much less expensive than from Sony. Google "TV-Parts" near (your zip) code or look in the yellow pages under that heading.
SOURCE:
KP-57WS520 Sony Projector - No picture
5 times blinks shows incorrect white balance (AKB) error. TV needs Screen Volts (G2) adjustment.
Take off lower front panel, find Focus Block that has 6 control knobs, adjust Screen volts of each CRT (red-green-blue) and problem will be solved.
Be Careful while working in TV.
Let me know if you have further question.
Thanks.
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
Hello..i have a sony kp-61v80 tv year 2000
I have a sony codes for sony TVs that tell what is wrong by the blinks as soon as a can will ck it to see what it says.
Dec 03, 2008 | Sony KP-57WS500 57" Rear Projection...
4 times flash of standby light shows that TV has problem in Vertical Deflection area and possible causes are IC1509(V out) is broken and / or Q1505(V Pulse Buffer) is broken.
Please check / test above said IF you have experience of TV repair.
Nov 29, 2008 | Sony KP-57WS500 57" Rear Projection...
Won't Turn on, standby LED lit
HI,
I am having the same problem, any solution? Thanks! -Steve
Aug 19, 2008 | Sony KP-61V80 TV
Sony - Projector TV won't turn
Sony TV;s will give a service code, count the blinks, eg; 2-6, light will blink X amount of times, hesitate & blink again so many times. Count and report back but, I would recomend to unplug the TV's power cord, to reset the TV's system. Unplug for at least 3 minutes. I hope this was helpful.
Jun 11, 2008 | Televison & Video
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
248 people viewed this question
Top Televison & Video Experts
Ekse
