Question about Symbol PDT 6846 Portable Terminal
I have a PDT6846 Symbol scanner that has an error now that seems to reflect a corrupt file. When the scanner boots it goes into an automatic telnet connection. That is when the error occurs 'FILE:: e:.\s24cfg.dat' You are then requested to press any key and the msg comes back 'Unknown Response 5 Returned by Telnet Configuration Program Check Termonal and/or Contact Symbol'. I have no manual and have inherited this equipement from the previous person at this job. I do have a scanner that works but need assistance to fix this.
  • john_arch870 Apr 27, 2010
    This answer did provide some insite to the fact that Motarola had more support for this product than what could be seen from non registered browsing.
  • 3,866 Answers
There is software on this unit that needs to loaded by the client server software from symbol. I been in the retial operations for a while and these things happend when the battery gets so darn low that the memory on these units seem to corupt the files. Now symbol is the best bet to get the software reloaded and will be your solution today.
There is really nothing you cannot do without the unlisted help of symbol as the software needs to be reloaded on this unit as a fix. Now lets say it does not take the software for some odd strange reason. then you need to have the hardware looked at. Now repair of these units are $150 respectively as far as hardware failure goes. But call symbol and ask them about the software reload I am talking about. Now the unit should have cable with a cradle to dock with the server to upload and download data in this case that is what needs to be done.
Thanks i sure hope this information finds the accept button as I did put a lot of effort into my knowledge to earn that. Thanks and Good luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 26, 2010
Symbol mc9060 telnetCE issue
I am unsure of which software you are using 'avalanche' is not what I am familiar with but if you want a decent telnet program then Putty is without doubt the most versatile and best in my experience.
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
I use it every day for all sorts.
Nov 11, 2013 | Symbol MC9060
Hoe to reboot pdt6840 scan gun
Warm Boot:
- Press the "PWR" button to turn the unit off.
- Press the "4" and "5" keys at the same time.
- While still pressing the "4" and "5" keys press and release the "PWR' button again.
- Release the "4" and "5" button.
- The PDT6846 should perform a warm reboot.
Cold Boot:
- Press the "B", "D" and "A" keys at the same time.
- While still pressing the "B", "D" and "A" keys press and release the "PWR' button again.
- Release the "B", "D" and "A" button.
- The PDT6846 should perform a cold boot.
May 03, 2012 | Symbol PDT6842-NIS632EU Portable Data...
Mc9090 laser stops working switching between sessions
Same here. Just started happening w/ scanners coming back from the EL PASO repair facility. Performing a "Clean Boot" on one running WM5 seemed to correct this issue. BUT, we have two other units w/ this problem that are running WM6, and the clean boot did nothing to help this.
Mar 13, 2012 | Symbol MC9090 Barcode Scanner
Symbol MC9090 Barcode Scanner cannot enable scanner error code "A0000008"
The scanner engine/output can be used only by one application. If a second application is trying to access the scanner, while in use. The error message will come.
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software. Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Oct 21, 2010 | Symbol MC9090 Barcode Scanner
Hello, my handheld symbol pdt6846 need load SLOADI to cingifure, i need to know how
The PDT6840 has 3 files loaded into it at any one time LWP.HEX, UDP.HEX and an application. SLOADI comes up on the screen during boot. You may require reloading of the software to enable this function again.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 09, 2009 | Symbol PDT 6846 Portable Terminal
Frozen PDT6846
Probably not -- looks like corrupt firmware -- it'll have to go to a Symbol/Motorola Dealer for repair.
Oct 27, 2009 | Symbol PDT 6800 Portable Terminal
Connect PDT6846 to Wavelink COM Server
you can get it from www.wavelink.com they are quite good and still offer the files for the older terminals. however, you may need to get a license from them in order to use it on the pdt.
Jun 05, 2009 | Symbol PDT 6846 Portable Terminal
Looking for mac address on a PDT6846
If you have loaded the radio drivers, exit to dos then type in CFG11 this will take you to the main configuration menu. From there press enter on the first option and voila. There you will be able to find the mac address.
Mar 25, 2009 | Symbol PDT 6846 Portable Terminal
TCP HOst Setup on a PDT6846
The host ip setup is application dependant. You'll need to check with the vendor that supplied your PDT6846 5250 emulator.
Feb 15, 2008 | Symbol PDT6842-NIS632EU Portable Data...
Symbol PDT 6846 Portable Terminal Logo
135 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
