Question about Destroyit 4605 Shredder
4605 CC wont turn on
Already checked the ff.:
power source
door closed
bag empty
clean photo cell
hopper down
main switch on
emergency shutoff
  • 86 Answers
Did you verify wall power? If good Then you might have button problem. I have 3 of these machines in the field.
Posted on May 13, 2010
Ir5070 error code E000025-002
The error code you have is a toner hopper error code.... Try to take the toner bottle out and close the toner door and turn the Main power switch OFF. Turn the copier back ON and let the copier come back to Ready and install the toner bottle back in and see what happens.... There maybe a problem with the toner hopper and you may need to call a service tech in.... Good Luck
Feb 27, 2013 | Office Equipment & Supplies
Tip
AEG Electrolux Lavamat 50600 is not spinning here are a few work throughs
Download manual
First off that was a link to the online user manual. If this was the first time using the machine did you follow the recommended first time use procedure by following these steps:
Before using your machine for the first time
0 Slightly pull the detergent compartment out of the control panel.
0 Pour about 1 liter of water through the detergent compartment into the washing machine.
When this has been done the ?KO lock can function correctly.
0 Run a wash cycle without laundry (COTTONS 95, with half the amount of washing powder).
This removes any residues from the drum which may have been left during manufacture.
If you have used this prior to the problem occurring try this:
The issues for not spinning are numerous as to what may cause this and it appears to be a lot but most of it is rather simple :
If there is water in the drum you need to follow the pump out procedure and remove water in the drum. Then there may be a "Bend" in the inlet hose. If there is water reaching the drum this is the possible causes and simple to check:
Water is leaking out from under the washing machine.
Fabric softener is not added, compartment for fabric softener is filled with water.
Appliance does not spin, water in the drum.
Washing has not been spun sufficiently, there is water left in the drum.
Door cannot be opened.
The rinse water is cloudy.Possible cause
The inlet hose connection is not tight.
The inlet hose has a leak.
The drain pump cover is not tight.
Washing is caught in the door.
Suction cap in the fabric softener compartment is not correctly fitted or is blocked.
RINSE HOLD selected.
SOAKING program is terminated.
There is a "Bend" in the outlet hose.
Maximum pumping height (drain height 1 m from the position of the machine) is exceeded.
Drain pump is blocked.
The water drainage system is blocked.
The door is locked due to safety reasons
Probably caused by a washing powder with a high silicate content.
Troubleshooting these are the remedies:
Tighten the inlet hose connection.
Check the inlet hose and if necessary replace it.
Tighten cover by turning clockwise.
Abort the program, remove the washing caught in the door, start a new program.
Clean the detergent compartment, fit the suction cap on firmly.
Deselect RINSE HOLD.
Pump out water and set the main wash cycle as desired.
Eliminate the Bend ( it would not allow me to use the proper word here see manual.)
Please contact AEG Service Force Centre, it has a retro- kit available for pump heights above 1 m.
I would definitely try this as it appears to the reset procedure for this machine:
Switch off the machine and pull the plug out of the socket
I would say no less than 20 minutes
but do this while waiting further:
clean the drain pump.
Clean the blockage
Carrying out an emergency emptying
1 Warning! Isolate the washing machine from the main supply before the emergency emptying!
If the washing machine no longer pumps out the water an emergency emptying must be carried out.
Warning! The water, which flows out of the emergency emptying hose can be hot.
First allow the water to cool down before emergency emptying!
0 Put down a flat container to catch the water draining out.
0 Pull down the flap in the left corner of the base strip and remove it.
0 Release the emergency emptying hose from its holder.
0 Pull the emergency emptying hose out a little.
0 Place a container underneath to catch the water.
0 Release the plug of the emergency emptying hose by turning it anti-clockwise and pull it out.
The water will drain out. Depending on the amount of water, it may be necessary to empty the container catching the water several times.
To do this, temporarily close the emergency emptying hose again with the plug. When the water has drained out completely:
0 Push and twist the plug firmly back into the emergency emptying hose.
0 Push the emergency emptying hose back in a little and let it catch onto the holder.
0 Replace the flap in the base plate and close it. When the washing machine is completely empty, the ?KO lock can no longer function correctly. Therefore before the next wash pour in approx 1 liter of water (pour it in through the washing powder compartment)
steps to Clean the drain pump
1 Warning! Switch off the washing machine and pull the plug out of the socket before cleaning the drain pump!
0 First carry out an emergency emptying (see section "Carrying out an emergency emptying").
0 Place a towel on the floor in front of the cover of the drain pump. Surplus water may flow out. 0 Unscrew the cover of the drain pump by twisting it anti-clockwise and pull it out.
0 Remove any foreign bodies which maybe in the pump housing.
0 Check whether the impeller of the pump can be turned. (It is normal forthe pump to turn in steps.) If the impeller cannot be turned at all please contact your local AEG Service Force Center.
0 Replace the cover (insert the ridges on the cover into the guiding slots)and screw on tightly in a clockwise direction.
0 Close the emergency emptying hose, push it in and twist.
0 Close the flap. I sure hope this helps a few people especially the one who I posted this for initially. GOOD Luck! If none of these suggestions work then best to call AEG for servicing, I strongly believe that the Bend in the inlet hose or the drain pump most likely the culprit and or any one of the other issues may well resolve the spin malfunction as well as possibly the main computer may have been goofed due to a slight power surge which unplugging from electric and turning off water for 30 minutes is the basic reset procedure for most electronics ( not all ;but most) while working through these steps should not hurt a thing.
on Dec 26, 2014 | Washing Machines
Can't open door of ASKO W6883
If nothing else works, the washer door can be opened as follows:
This must only be done in an emergency
if the machine's glass door does not open automatically when the program has finished.
First check that there is no water left in the machine. If there is water left in the machine and it is not possible to run the Drain program, empty the machine by using the drain hose.
Make sure that the main power switch is off and that the plug has been re- moved from the wall socket.
You will find the emergency opener for the glass door in the double sealed bag.
Open the glass door by putting the opener in the slot to the right of the lock on the door. Push the opener up or down and the door will open.
Feb 28, 2011 | Asko W6021 Front Load Washer
Dvd dvd door will not stay closed. tried turning off and on multiple times. just keeps popping open.
Reset your player. Press and hold the FF and RW buttons at the same time on the main unit itself for 5 secs. Afterwards, unplug the player from the power source and let it sit unplug for a minute. Plug it back in to the power source and turn it on.
If its still the same issue,I just want to inform you that your unit laready needs service for repair.
Sincerely yours,
Genius 101
Oct 22, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
AWM8143
FA is the emergency shutoff switch that detects when water is pooling underneath the machine -> a leak.
"Check float switch under machine, empty any water from catchment tray, check for water leaks or oversudsing".
Jul 10, 2008 | Whirlpool AWM8143 Front Load Washer
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Toner
Di200 [Subject] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good. [Description] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good.
[Solution]
CAUSE: Inside the sub hopper, the magnet (P/N 9326-2900-06) may be catching on the inside of the hopper, preventing proper actuation of the Sub Hopper Toner Empty switch.
SOLUTION: Make sure that the actuator can move freely up and down when no toner is in the sub hopper.
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
Achiever ccs 5000 no power at all
hi check these before enything: 1) check with another device that the socket has power 2) check cable is good all the way (NOT torn, twiched, squashed) 3) the device is hooked up good (in place,NO trash) 4) there is a micro switch on the door which wont let the device work without no good connection 5) check good fuse should work good luck
Apr 05, 2006 | Achiever CCS5000 Shredder
Destroyit 4605 Shredder Logo
74 people viewed this question
Top Destroyit Office Equipment & Supplies Experts
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you a Destroyit Office Equipment and Supply Expert? Answer questions, earn points and help others
