Question about GE XL1800 1100 Watts Microwave Oven
Stove won't stay lit!!
If my gas stove turns on, but quickly dies away, is there a problem with my stove or the gas?? I hear the little gas noise, so... then, how do I fix it if it is the stove??
  • 981 Answers
So, you cleaned the burner per the manual (or the one you looked at when visiting the appliance store,) and it still flames out right after coming on? Sometimes things catch in the works and there are a few methods to clear them out (e.g. at the controls) depending on the model. Beyond that,in order to disconnect the stove and check the inlet filters, you might want to call the appliance or gas co for a technician. No use having leaks, searching forever for the main shutoff valve, etc.
Posted on Mar 24, 2008
Gas stove keeps blowig out,sometimes stays lit for a long time an other times just minutes. wot could prob be
Posted on Dec 18, 2011
My oven will turn on but won't stay lit (
The light may be loose, or one of the micro switches are going.
Apr 03, 2012 | Whirlpool Microwave Ovens
My surface light bulb burned out and I replaced it with a new bulb. But now the bulb stays lit and it won't turn off even though I turn it off from the light switch. Please help.
The only fix for it is to either buy another control board $300+ or if you are any good at wiring you can go the the hardware store get a manual toggle switch and install it under the microwave on the right hand side near the control area. But make sure the switch can handle the heat rising from the stove burners. We have about 120 of the microwaves on our properties and 6 of them have this issue. The relay internal switch becomes corroded and binds together from steam and boiling water. GE is JUNK.
Oct 30, 2011 | GE JVM1790 1000 Watts Convection /...
I have a gas Viking range. The oven burner ignitors light up and ignite the gas burners but quickly shut off - then go on again and off again- intermittently but frequently. This does not permit the...
Here is a test you can use to check the ignitors, Ignitor test. I also would like to you turn the thermostat knob slowly from the off position, When do you hear the click in the knob? You should hear it before the warm or lowest numbered setting on the knob. If you don't, replace the thermostat as it has failed. Need full model number to get you part.
Good Luck
Stay dry out there!!
Aug 28, 2011 | Microwave Ovens
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jul 03, 2011 | Microwave Ovens
I am painting in my kitchen and it is recommended to turn off stove pilot gas so know combustion happens. I have a Tappan gas stove that says "electronic ignition" on it. How do I turn off...
If you have an electronic ignition, there are no open flames. So you are ok to paint. Just make sure to not turn anything on while the paint fumes are in the air and you will be good.
If you do want to turn off the stove, unplug it from the wall. To turn the gas off you will need to pull it away from the wall and turn off the valve behind it, if it has a valve, some do not.
Apr 23, 2011 | Microwave Ovens
Top left burner (propane) does not seem to be receiving gas when trying to ignite it with electrical igniter (control knob). However the burner can be lit with a match when the control knob is turned past...
The igniter usually sparks for all burners on the stove at the same time. Usually a little water or gravy, or such has gotten on the little spike that stick up and throws the spark to the burner. If you will take a small brush, like a tooth brush and carefully clean around the little spike it normally starts sparking again. As it is right now, you should be able to see the spark on all the burners whenever you start any of the burners. Check to see on the one that is not lighting, I think you will find that it is not sparking at all right now.
Sep 21, 2010 | Microwave Ovens
20" gas stove: has pilot light in oven, oven lights but then after several minutes will turn off. do not smell gas after it turns itself off. Using 3/8" gas line. Please advise as to potential problems...
The oven igniter should stay on constantly as long as oven control is calling for heat and not fade off. If the igniter is too weak and not pulling enough current it may not open the gas valve correctly and gas will be let out of the gas valve and not igniter.
The likely failure is a weak oven glow bar igniter. I recommend calling a service technician to diagnose and repair your range.
Hope this helps .
Apr 21, 2010 | Microwave Ovens
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
GE XL1800 1100 Watts Microwave Oven Logo
1,503 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
