Question about Toshiba 65HM167 65" Projection Television
Yellow light blinking on tv will now come on - Toshiba 65HM167 65" Projection Television
  • 4 Answers
If you are refering to the 3 yellow blinks repeated over and over the
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses,I used a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
Posted on Apr 29, 2010
  • 7 more comments
  • jgyfeb23 Aug 27, 2011
    I am having the problem with the 3 blinking yellow lights and when I contacted Toshiba it is no longer available for download only a service tech or service provider have access to this firmware file( update firmware for 65 hm 167, Does anyone have it to share? Please help.
  • gallegosrg Sep 21, 2011
    does anyone have this download. Toshiba will not allow any downloads of this firmware and the tv is basically useless at this point.
  • bigdufus Sep 21, 2011
    file name is 2007sen069.zip, we have found you cannot use an sd card larger than
    2 gig
    file is herehttps://rapidshare.com/files/4153045258/...
    https:rapidshare.com/files/4153045258/2007sen069.zip
  • Malcifar Dec 24, 2011
    Thank you so much for this! It worked! I am especially grateful for the rapidshare link to the firmware that is no longer available through the Toshiba site. It is wonderful that there are still people out there who take the time to upload and post solutions for others. :)
  • Kim H Jan 04, 2012
    You are awesome!!! Worked like a charm once you get the right link from RAPIDSHARE. Thanks soooooo much!
    Lim H. Southern California
    You are awesome!!! With the right link from RAPIDSHARE, this worked like a charm. Thanks soooo much!
  • stump807
    stump807 Mar 10, 2012
    Will that file "2007sen069.zip" also work for my Toshiba 57hm167? I believe their basically the same tv except for the difference in size. If it won't work for the 57hm167, does anyone know where I can find the right firmware for it? I'm wanting to know cause my tv is doing that same "3 blinking yellow light" thing. Any help would be appreciated. Thanks.
    Problem Solver:
  • 7 Answers
I've been trying the above solution for the past 11 hours and no luck :-( I was hoping I'd be one of the lucky ones like the above. Does anyone have any other ideas for the same problem? Any help would be greatly appreciated!!!! Thanks in advance
Posted on Aug 21, 2012
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual:
Blinking yellow= Lamp cover is open.
It could be something else!
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD-57731 57" Projection HDTV
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
My toshiba 50HN67 TV won't power on.
hi
can u tell how much times the light blinks..
then i can give solution...
thank u,,,///please rate it
Jul 02, 2009 | Toshiba 50HM67 50" HDTV
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another click but the tv never comes on.
What light do you get, green blinking, red blinking, yellow steady light or yellow blinking light. The led lights will tell what is wrong with your tv.
Jun 12, 2009 | Mitsubishi WD-52327 52" Rear Projection...
No picture yellow standby light blinking
how old is the tv is it possible your lamp is burned out this is what a dlp screen would do.
Apr 14, 2009 | LG RU-52SZ51D 52" Rear Projection...
Toshiba 65HM167 65" Projection Television Logo
1,531 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
