Question about Kitchen Ranges
A kenmore front loading washer is getting an error f-24 its approx. 4 yrs. old.
  • 1 more comment
  • J-run Apr 26, 2010
    Your help has been awsome, I really appreciate your thoroughness in getting all the info i would need. Is there a way that i can always come to you for help. I'de recommend your name to anyone. thank you very much
    Dude i dont mean to sound stupid, i'm trying to find where i write a testimonial, i see where i can read all of yours, but how or where do i go to write one
    Again I really appreciate the effort you put into getting all that info. you were very helpful
The "F24" error code is a heat sensor error code, the connector plug on the NTC sensor wiggles loose and causes this code Click on the link below, it explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
Posted on Apr 26, 2010
  • Anonymous Apr 26, 2010
    You can write a testimonial of my answer to your Kenmore F 24 problem. If you do that, you will find my name every time you log on to Fixya. I am on 24/7 and knowledgeable in many subjects. thank you and have a nice day.
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
Excessively noisy when it spins. The faster the spin the noisier it gets.
Sounds like the Drum Bearings are gone they are **** on Hotpoint..Could be quite expensive depending on age...3 years old you will need a half drum complete with Bearings approx cost £80 plus labour....if more than 4 yrs old then perhaps bearing kit plus 3 hrs labour....Hotpoint give a FREE 5 yrs parts warranty however CALL CHARGE....£105 approx parts are free.....You need to ecide if you should fix or just buy a new one........
Jan 14, 2011 | Hotpoint WMA58 Front Load Washer
My Kenmore Elite washer will not fill.
yes there is a water inlet valve . it is the blue valve your water hoses connect to on the rear of the washer, they get sediment built up inside and get stuck , cost $26.50 from Repairclinic.com just go to site .find parts,then type in your model#
Jan 21, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Electronic display was flashing LE. Unable to open front load washer...no visible water. Tried to restart...unable. What is your best solution to open front and get washer working again? washer is...
Waht make? Model?
Sounds like an LG
You might want to unplug the unit for 10 min -then plug it back in and then power up , then press pause.
LE- could be a motor sensor, main board issue - wiring issue
Affordable Appliance repair
Orange County, CA.
Aug 22, 2009 | Washing Machines
Water won't run into washer - clicking sound only front upper left like plastic gears running over each other
The fill valve is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore Washing Machines
F6 error problem
F6 is a communication error. It is either a loose connection to the control board, or the control board is shot. They should have diagnosed this when they came out to fix it. Open it up, and look for loose connections.
Apr 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 22992 top load washer
Remove the front panel and youll see.
May 20, 2008 | Kenmore 22422 Top Load Washer
Kitchen Ranges Logo
18 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
