Question about Windsor SR12 Sensor Bagged Upright Vacuum
How do you change the belt on a winsor sensor s12?
I'm not sure how to check or change the belt on a Windsor Sensor S12 upright sweeper?
  • Anonymous Mar 13, 2014
    Brush indicator light stays on all the time.
  • 438 Answers
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Windsor vacuums.
If you have any further questions on how to replace the belt, please feel free to reply to this repair by leaving your question in the comment section, I'm always more then happy to answer any question you may have.
Thanks again,
Chris Jones
goVacuum.com
Posted on Apr 27, 2010
  • canuck 99 May 24, 2011
    i have a SR 12 how do you take off the vacuum bag housing
  • Noreen Wixon
    Noreen Wixon Jul 21, 2016
    probably not going to get this, but how do you replace the motor belt?
How to fix sensor s12. red light for bag stays on even when vacuum bag is not full and the vacuum is clear
You most likely will need to change the Yoke assembly. There is a sensor built in that gets clogged with fine debris over time. This will take care of the problem.
Feb 09, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
I have windsor s12 red light for bag is full is on and it's not clogged. what next
Check the line going from the bottom of the vacuum to the bag, it may be clogged. A coat hanger can help you clear any jams, but be careful not to puncture the duct.
Jan 27, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
How do I replace the front bottom plate on my Sebo X4 Extra vacuum cleaner, this is the metal/plastic plate on the front base of the bottom of the cleaner (no visible fixings)
With the power head cover removed, you will see tabs on the inside of the chassis inline with the front bottom plate. Simply pinch the tabs with some needle nose pliers and push. I have included a link to the parts list as well as the front bottom plate. You will see by the picture what those tabs look like and how to remove the front bottom plate. 5411 HG Front Bottom Plate Windsor Sensor S12 XP12 SR12 86138280 allstar... http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Dec 09, 2014 | Sebo X4 Extra Bagged Upright Vacuum
Why doesn`t the height adjustment wheel on my windsor vacuum go up?
There are (4) main components that affect the height adjustment on your vacuum. They are: Brush roller, Servo Motor, Control board, and Sensor pulley. You have eliminated two of the possibilities already. I would ask you if either of the height adjustment lights on the PC board come on, indicating that the board is attempting to raise or lower the vacuum. I would also have you inspect the Sensor Pulley. That is the yellow pulley that both belts connect to. Do the two sections of the Sensor turn easily without resistance? Do they spring back when released? Are the magnets (small black round magnets on the inside of the Sensor wheels) still in place? That Sensor pulley system tells the PC board whether or not the vacuum needs more or less resistance (to raise or lower the servo motor). Because the Sensor Pulley is completely mechanical (no electrical components); If this Sensor pulley is completely functional, your problem is likely the PC board. I have included some links to the PC board and Sensor pulley for your convenience. Hopefully this helps. 5465 Red Ring Windsor Sensor 86145060 5740 ER Computer Controller Windsor Sensor SR XP 86140160
Sep 09, 2014 | Winsor Windsor Chassis, Gray Xp15...
The handle release on windsor s12 won't spring into place
You likely have one of two problems. Your return spring is broken, or your axle is bent. If your axle is bent, carefully inspect your chassis to be sure that the bent axle has not cracked or otherwise damaged the chassis. I have included a parts list as well as some links to these parts for your reference. http://windsorvacuums.com/partslists/s12_PARTS.pdf 2010 Axle Spring 86146570 windsor allstar javelin 5053 Windsor Sensor Axle 86137990 allstar javelin
Jun 17, 2014 | Windsor VS14 Versamatic Bagged Upright...
Servicing windsor sensor xp15
You need to replace your beater bar more than likely, if the light stays on all the time. If it is flashing there is usually something jamming the brush roller from turning properly.
Jan 27, 2013 | Winsor Windsor SENSOR XP15 Vacuum
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
I have windsor s12 vaccum this one have brush up light on
The windsor Sensor brush indicator light will come on when:
  • Something stuck in the brushroller
  • Brushroller is worn and needs replacement
  • height is wrong (indicates a problem with height adjustment)
  • a bad circut board/sensor
more than likely your brushroller just needs to be replaced, very common.
Jun 03, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
My windsor s12 vacuum light says the bag is full but it is new?
It sounds like a blockage in the hose or in the yolk.I believe you can remove the hose from the machine to inspect and clear it.Also check the trapdoor on the bottom of the powerhead to be sure it is clear.While you are going through the machine check under the upright filter next to the bag to see if it is clear.Good Luck-Scott
Oct 10, 2008 | Vacuums
Windsor Sensor 12 Vacuum No Power
I'm an engineer for Hyatt hotels and I've worked with the S12 vacuums for a few years now. The most common problem electrically lies in the main switch and the power cord. Almost at no time in the past three years and working for 4 hotels have I had to replace any motor or board component for them. Take out the handle from the bag housing and use your volt meter/circuit tester to test the main switch, if that and your power cord are good, then you might have a bad fuse, which is located on the brush side of the main chip board. Any other questions, feel free to email me directly @ andrew.massey@gmail.com
Oct 20, 2007 | Vacuums
Windsor SR12 Sensor Bagged Upright Vacuum Logo
1,263 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
