Question about Bosch Nexxt WTMC 3300 Electric Dryer
Dryer is not heating to dry clothes
My dryer has stopped heating to dry the clothes.
  • 78 Answers
If its not heating at all, first check electrical and make sure your getting 220 to the dryer if you are more than likely its the heating elements, check them and replace if bad
Posted on Apr 26, 2010
It heats up but doesnt stop after the clothes are dry
IT is the timer. If electronic needs to replace the board. If dial type, needs the timer
Sep 15, 2014 | Dryers
My dryer stops drying after 10 min. All the lights flash on the right hand side. I've tried different drying settings and different amounts of clothing. Nothing works. What's wrong?
My dryer does the same thing. Additionally, it is not heating what so ever. Clothes are cool and damp, and heating vents at back of dryer are cold to the touch.
May 11, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Our dryer stopped heating up and will not dry clothes
tif it is most likley the element has gone bad they usually cost about 45 dollars and if you can find a friend to help you replace it its not that hard best bet is to call a used appliance store they usually have them new and in stock do not try going to the manufacture they will charge you double for the same exact part
Apr 12, 2010 | Maytag SDE3606A Electric Dryer
Dryer is heating, but stops before clothes are dry. could this be a sensor issue?
Timer might not be calibrated correctly. Could be the amount of clothes and how heavy they are (e.g. blue jeans?). Give the clothes more time to dry
Jan 02, 2010 | GE DCVH515EF Electric Dryer
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
Drying clothes & the dryer just stopped & won't come back on
This is likely the thermal fuse on the heating element. You can check it with an ohmmeter. Also clean out your venting, as this often causes it to blow. Hope this helps!
Mar 09, 2009 | Maytag PYE2300AY Electric Dryer
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Bosch Nexxt WTMC 3300 Electric Dryer Logo
300 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
