Question about Mitsubishi LVP-X50U Multimedia Projector
My projector shows the screen split in half with the right on left and left on right with a black space in between. What is the problem?
4 Suggested Answers
SOURCE: Projector shows only 50% of the computer screen
If you can bring up the settings menu, go to the magnification setting and reset to 1X, you won't see part of the menu either and have to guess at the setting, but it will pop back to full screen when you get it. It will revert so memorize where the setting is and how to fix it when you can't see the menu.
Posted on Nov 01, 2007
Gurudristi
  • 98 Answers
SOURCE: Half of monitor screen shows on the projector.
You will need to set your computer to the correct display properties.
This you can do by either going to presentation mode.
Alternatively,
on Window XP you can simply go on to your desktop and right click > go to properties>go to setting> press display 2 and set the screen resolution as per your projectors resolution and enjoy.
( for information: display1 is the resolution meant for your computer).
Please do rate this solution and Thanks for usinf FixYa!
Posted on Mar 13, 2009
  • 556 Answers
SOURCE: WD-52525 split screen
what are you using as input? On this set only digital channels can be the main picture. You can try the exch button to see if it comes back right also.
Posted on Aug 11, 2009
Sharp 46" 6 months old see rainbow colors from left to right
Did he change the big video board?The main backlight video baord that the prob.
Oct 23, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Alternatively,
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Projector
Hi there
You can right click on your desktop and go to properties and then settings. Chech if your secondary monitor is activated.
If it is and you still can't pick up a signal - Hold down the Fn ( function button situated in the bottom row left of your space bar ) and in your F-buttons at the top there should be one with two screens on it. That splits the screen and pushes the image to the Projector.
Dec 10, 2007 | BenQ PB6110 Multimedia Projector
Panasonic tv TC-26LX60 PICTURE PROBLEM
if this is under warranty still, i would take it to a service center or rma it to panasonic.. if it is not under warranty, you can try the following.
1) try a different video source and verify the problem is happening on all video sources and modes.
2.a) if the problem is not happening in all modes, remove and replace the cable that is causing the issue. if this doesn't remedy the problem, the controller for that particular input is going out
2.b) if the problem is happening in all modes, you can open the case and carefully disconnect and clean (de-oxit or rid-ox) the hirose style connectors on the back of the display panel.
3) disconnect and clean all ribbon cables around the display panel
this sounds like either the connectors are not performing adequately or are loose, the top ribbon is acting up for some reason, or the graphic controller is going out.
Nov 15, 2007 | Televison & Video
HP Pavilion dv6337us screen problem
Place you cursor on a blank spot on the black area, Hold the left mouse/touchpad button down and drag it back down to the bottom of the screen. That should get you back to where you want things to be.
If that fixes it, please return here to rank this as solved. If it doesn't, let me know and we'll see what else we can come up with. ;o)
Ron-
Nov 08, 2007 | HP Pavilion dv1000 Notebook
Vertical control of viewing frame needs adjustment.
Did you try going into MENU --> PICTURE --> SIGNAL MODE, and then pressing > to go through all the signal modes? On mine, most of the signal modes split the screen weirdly as you described, but one of them (in my case XGA3, but I'm not using a Mac) looks right.
Nov 07, 2006 | Polaroid Polaview 211E Multimedia...
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Mitsubishi LVP-X50U Multimedia Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
