Question about Frigidaire FEF336BC Electric Kitchen Range
I don't know what model my stove is/the element is out?
My electric Frigidaire stovetop/oven looks like the one pictured. However, I can't find the model number on it anywhere to be 100% sure. Where would the model number be located?
I am assuming that I need to order new top and bottome heating elements. While baking there was a loud pop and they stopped working.
Is this something that I can fix by just ordering new parts?
  • 1,284 Answers
Hi, what you have is a Frigidaire FEF336BC Electric Kitchen Range.
You can talk to the technical support of Frigidaire on what happened, and they will definitely advise you on what to do..
Take care
Posted on Apr 26, 2010
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven
Yes, that sounds like a relay on the oven control board. Here is the part to order that has a 365 day, any part, any reason return policy so you may want to order from them.
Jun 25, 2013 | Ovens
We have a ceramic top electric Frigidaire model GLEF378CCS. Neither the broil or bake elements work in the oven. Stovetop elements are fine.
check all wiring connections, if ok ohm out oven thermostat, if thermostat ok, ohm out oven elements and if ok, check voltage at oven elements. isolate problem.
Jan 25, 2011 | Kitchen Ranges
I replaced an element in the oven of a frigidaire model fef366emd and somehow one of the spades came off the element without my knowing, I turned it on to see if it would work and I heard an electric...
all repairs should be performed by an authorized service person.you may have blown your home electrical breaker for the range. reset the home breakers make sure you reset both breakers. high voltage ranges have dual switches.the range should work after resetting the breakers.
Jun 02, 2017 | Kitchen Ranges
While using stovetop had turn oven on for a few minutes heard a pop and smoke from back of stove. fuse blown?
It's unlikely to be a fuse. Those are the classic signs of the heating element burning out, in which case you will need a new element. Burnt out elements can't be repaired. If the fan still runs but the oven doesn't heat up, it's your element.
Regards,
BElectric
Nov 30, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FEF336BC Electric Kitchen Range Logo
79 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
