Question about Baumatic 23 in. BDW5 Built-in Dishwasher
Failure with control unit or heating elemint failure
  • Baumatic Master
  • 43,501 Answers
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
Hot water is intermittent
YOU PROABALY HAVE A BAD THERMEL COUPLE OR BAD HEATTING ELEMINT OR MAYBE THE PILET LIGH IF GAS IS TO LOW. IF ELECTRIC IT MAY BE SET TO LOW OF HAVE A BAD CUT OF AND ON SWITCH
Feb 27, 2014 | Camp Chef Camping, Backpacking & Hiking
Water not heating
Possible failure of the heating coils,you need to open the check the continuity of the coils to confirm. If the coils are good then there is no voltage from the program controler unit at the time of the cycle for heating . Hence it is possible that the controller unit / relay is faulty.
Sep 27, 2011 | Dishwashers
Compressor & fan not running.
Hi and welcome ti FixYa, I am Kelly.
Since you did not include your model number this will be a GENERIC response.
Reasons for the compressor and fan not to run.
1. Defrost control problem. Mechanical defrost timer stuck or failure. On units with Electronic Adaptive Defrost controls; a PCB failure.
2. Defrost thermostat or defrost heating element failure.
3. Fresh Food temp. control failure.
These are the 3 most common failures. The fans should run anytime the units temp control is above the "set temp" and the unit is NOT in the automatic defrosting cycle.
If you provide a model number I can pass on some troubleshooting tips to hopefully help you isolate the failed componenet.
Thanks for choosing FixYa,
Kelly
Jan 26, 2011 | Kenmore Refrigerators
My Miele G646sc dishwasher is not heating the water and therefore there is deposit of water at the end of the cycle. Please help.
Both the issues seems to be apart. The loss of heating is due to failure of the heating coil, failure of the heating coil control relay , failure of the program controller unit.
All of this must be checked with a multimeter only if you are able to remove and check the control panel of the washer.
Secondly the drain pump/valve can be clogged and is not fully exiting the water after the program comes to an end as the time given to pump out is not sufficient due to low flow - clogging with dirt.
Remove the drain hose/ drain pump and clean the filters , reset the valve/pump to test.
Jan 06, 2011 | Dishwashers
While cooking a potato the unit just quit heating. Still sounded like it as working but no heat
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if your unit has power, and things lite. it is more likely you have a control/switch problem,
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | GE Microwave Ovens
Programmable Thermostat Heater: no power to honeywell central heating control...
Multiple possibilities:
Damage to cable (doing any DIY?)
Failure of thermo
Board gone in heat unit
Possibly simple as loose or disengaged connection, check at thermo & heat unit, if nothing obvious, call serviceperson.
May 18, 2010 | Honeywell Programmable Thermostat Heater
Drum turns but has no heat
seems to me the heating elemint may be gone. You may have one or two in your unit but if your getting NO heat both may be gone.
Nov 28, 2009 | Dryers
Where is the heating elemint
If the model number you have this listed under is correct, you will need to open the panel under the door. This is accomplished by removing the screws under the bottom edge of the lower panel. HINT: If you prop up the front feet of the dryer, it makes access to the screws much easier.
With the screws removed, the panel will drop down and off. The heating element is located on the right-hand side under the drum, inside a heater box. CAUTION: Make sure you UNPLUG the dryer before servicing anything inside the unit. Dangerous voltage is still present even while the unit is turned off.
Is there any reason why you need to know where the heating element is? Do you have a heating problem? Please elaborate?
If the model number is not correct, please post back with the correct information. If you need further assistance, please let me know. I hope you find this information helpful.
Mar 05, 2009 | Whirlpool GEW9250 Electric Dryer
Baumatic 23 in. BDW5 Built-in Dishwasher Logo
101 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
