Question about Dometic RM2852 Refrigerator
9 year old dometic will not get12 volt power. Installed a new power board had has same problem. 120 volt goes into the board and gets no 12 volt out. Anything I can look for?
  • Dometic Master
  • 6,674 Answers
There should be 12 volts connected at lugs near bottom of back of fridge, behind vent cover. Not there?
Posted on May 09, 2010
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
Rm70 will not do anything
check voltage coming in 120 volt for heater element 12 volt runs fridge if fuse ok and 12 volts bad board
May 22, 2014 | Dometic RM2652 Refrigerator
Wire hook-up
see schematic on side of inside back cover if 120 volt plug that goes to outlet then if 12 volts from black and green ground go to block they should be marked
Jun 18, 2013 | Dometic RM2620 2 WAY REFER
Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Mar 24, 2009 | Dometic NDR 1292 Refrigerator
Dometic RM2852 Refrigerator Logo
201 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
