Question about Epson TM-T88III (C420863)
When I print receipts it looks like it is missing a column. Like the last digit of the credit card number and last number of the total price i.e. $29.3 How can I fix this?
    Genius:
  • 1,027 Answers
Print head needs cleaning, OR that column has burned out and the head should be replaced.
Posted on Apr 26, 2010
Tip
Traveling Abroad With a Credit Card
Before you take that long overdue Caribbean vacation, be sure to let your credit card company know when you will be abroad. Some companies will block any foreign purchases if they suspect that you aren't the one making them. <br>It's a good idea to check the limit on your credit card; knowing how much you've got at your disposal can help avoid some uncomfortable and possibly embarrassing situations. Make sure you know the number to dial if you need to report a lost or stolen card. <br>Once you've arrived at your destination, be sure to pay attention to your receipts; it is all too easy for a vendor to charge you $100 for the hat you wanted instead of the $10 price that was advertised if you aren't paying attention.<br>Always keep your receipts for at least 60 days so that you can dispute any purchases if necessary and file a complaint,<br>Finally, check if you are eligible for any waivers or discounts on things like baggage fees or rental cars.<br>Have a great trip!
on Aug 21, 2013 | Finance
I cant fond the door lock code, could you help me out
Get a flashlight. Lie on your back on the drivers floor and look up under the dashboard. To the left of the steering column on the firewall there will be a white box (6" X 3"). On the box is a label with part numbers and date codes. On that label you will see a 5 digit code printed a little darker than the rest of the print on the sticker. That is your code. If you have your original owners manual, look inside for a plastic card (credit card size) with a 5 digit code on it. That is your code. If all of this fails, goto your ford dealer and they can get the code from the vehicles computer
Apr 15, 2010 | 2000 Ford Expedition
How can i use credit card mashine
Following are the steps to use credit card machine
step1:Input the credit card numbers.If you have the credit card in hand, swipe it through the card reader. Most readers have a small icon or picture on them that shows which way the magnetic strip on the back of the card should be facing. If not, try running it
through the reader with the strip facing the machine first, since that is the most common direction. If you have a phone order, or do not have the credit card in hand, select the button marked "sale." On many machines this is also the "1" key, but it varies depending on the brand of the machine. Then follow the on-screen prompts to enter the card number and expiration date. Always double-check the numbers before pushing enter
step 2:
Input the sale information.Typically, the machine will first ask for the sales amount in dollars and cents. Input the amount using the number keypad. Double-check the amount to make sure it appears correctly on the screen and if it does, then push enter. If you accidentally input the wrong amount, look for the "clear" or "delete" key and start over. In some cases, the machine will prompt you for additional information after you've entered the sale amount. Follow the prompts to enter information, such as the customer's zip code or an order number.
step 3:
Wait for the sale to process. Depending on the machine's connection the sale may process within seconds or it may take a few minutes. If the machine seems to become "stuck" while processing a sale, do not re-enter the sale, but instead call the processing company's phone number for further instructions. In many cases this number will appear on a sticker on the machine.
step 4:
Process the receipt.If the customer is present, have them sign the credit card receipt. Give them the copy and retain the original for your records. If the customer is not present, write "phone-in" or another appropriate phrase on the signature line of the receipt. Keep one receipt for your records and include the other in the shipment of the goods to the customer.
step 5:
Close the batch.Double-check with your processing company, but most require you to run a "batch report" or close a batch of credit card receipts each day. This is the process that tells the company to finalize the credit card charges and deposit the balance to your account. Many machines will have a key that is marked "batch." You can press this key and then follow the prompts to close the batch at the end of the day. If the machine does not have a "batch" key, consult the user's manual for instructions or call your credit card processing company for instructions.
Thank you
Mar 14, 2010 | IBM Domino.Merchant Server Pack Upgrade...
Need the printer to only print the last 4 digits
To solve last 4 digit issue.
It need to reprogram Tranz 330.
Not buying Printer
this model is not compatible with PCI compliance.
contact your processing company and let them reprogram this.
http://www.gorillapaper.com/verifone-printer-p-250.html
Mar 09, 2010 | VeriFone 250 Matrix Printer
Credit card receipt for on line purchase
Priint the transaction as you proceed with it if you're not sure about getting a formal receipt. You should get a confirmation number as well as a confirmation email.
Apr 24, 2009 | Motorola Mobility TracFone® V170 Cellular...
IBM 6400 missing decimal...
is there print missing??? if so the hammer fret in that location probably (90%) needs cleaning as dirt can get between the fret, it only takes the smallest amount of debris to stop fret working, you need to remove hammer bank to do this, fairly simple to do just lots of screws. the only thing to check when reinstalling hammer bank is that you pull it towards you ( front of printer ) before tightening the 3 screws, this is to be sure the gap between hammer bank and platen is roughly correct. there are 2 small grub screws at each end of platen to adjust this gap if you need to.
Aug 06, 2008 | IBM 6400 Matrix Printer
Duplicate receipt
Will your credit card company provide documentation?
Will the store you bought it from help you by providing a duplicate?
Some manufacturers will let you sign an affidavit in lieu of a receipt. Also, some manufacturers simply use the serial number or date code to validate the warranty.
I would contact the dealer about a dupe receipt first, then contact the manufacturer to see if they allow an affidavit or use the serial or date code.
Your last resort might be to contact the credit card company.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | Microwave Ovens
Epson TM-T88III (C420863) Logo
121 people viewed this question
Top Epson Televison & Video Experts
janman
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
