Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
MY REMOTE DOESN'T WORK AFTER I CHANGED THE BATTERIES. WILL I HAVE TO GET A NEW REMOTE? AND IF SO, WHICH ONE TO WORK WITH MY TV?
    Scholar:
  • 62 Answers
Just changing the batteries would not cause the remote to go bad. check the way you have put the batteries in, put a neww pair of batteries, see the terminals inside the remote are clean? If it does not help then you can choose a dedicated remote for philips tvs that does not need programming. These cost $5 to 15.
Posted on Apr 26, 2010
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
TV 1 does not pick up Dish, scanned but doesn't show Dish
1) change the new batteries
2) Clean the contacts batteries very well
3) retight the springs contact for better contacts batteries
4) Open the remote and clean the keypad with special spray contacts cleaner.
Otherwise you must go to the repair shop.
download again the code: www. fitness.manualsonline.com
God bless you
May 23, 2012 | DISH Network IR Remote Control
Our remote died to our Vizio ....checked batteries, etc...have been having problems for a while...bought a new universal Vizio remote...keyed in all the numbers....last four work...but still is not...
New TVs and older ones, even recent model changes usually have different codes. Read the new remote closely. there is a section about finding the code manually. It is a pain, but works.
May 30, 2017 | Televison & Video
My TV remote control has stopped working. I've tried changing the batteries but it still doesn't work. Any tips or do I have to get a new one?
Check for rusted battery contacts due to leaked batteries. Clean them with polish paper or blade. Due to leaked batteries it is quite likely that the wires connecting remote control pcb & battery contacts are cut off.
sonsunny
Jul 02, 2011 | Televison & Video
Remote doesn't work even with new batteries
make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
May 28, 2011 | GPX Televison & Video
It doesn't work
is this a remote to TV or what? I am assuming it's a remote to a TV. If it is not for a TV, let me know, although, the solution is similar to any unit that uses remote control.
There are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Yours sincerely
Elect_Comp
May 14, 2011 | Televison & Video
My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
May 08, 2011 | LG 32LC7D Television
Remote doesn' turn n tv or chane channels
try changing the batterys. If its a universal remote reprogram it again.
Oct 04, 2009 | Symphonic ST420FF 20" TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
