Gain on one channel stuck at max
On my NAD 304 ampilfier, one channel is stuck at maximum gain, even with the volume knob all the way down. The other channel seems to work fine. I've checked the RCA connections, and tried a few different inputs (CD / Tape specifically). The problem seems to be in the preamp section, as if I connect an external preamp to the amp section, things seem to work OK. Is this something reasonably common such that I'd know where to look for a DIY fix, or is the amp ready for the bin?
  • 1,512 Answers
Hi there
Check for a dry solder joint on one end of the vol control(earthy end). This will be causing your problem. The pot itself may actually be faulty to. You can always get stuff like that, just got to identify it. Check soldering to the pot first.
best regards
Graeme
Posted on Mar 24, 2008
SOURCE:
I have a Behringer 1002 mixer. Applying 0 dBu unbalanced to the input I need the -10/+4 control in its most sensitive position to acheive 0 db out with the main output control set at 0 dB. Is this cor
Depends on the input you are using. First you need to calibrate signal coming in with the Gain attenuation knob. Setting this prior to adjusting your channel output volume should calibrate the signal so when the channel volume knob is set to 0 and the Main volume is set to 0, the meters should indicate a true 0 reading.Not setting the Gain correctly will affect this. On the 1/4" channel inputs, you have less adjustment and may have to adjust the item you are plugging in from its source. If you are having issues with high gain, chances are it could be a cable issue, or something from the source itself.
Jun 06, 2012 | Behringer 1002 10 Input 2 Bus Mixer
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
What are the proper knob settings for a galaxy DX99V
prefferably on . sq to point that radio starts to hiss . then RF gain about 3/4 open along with power gain . clarifier set to channel you are monitering . volume your choice.
Jan 20, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
How do you connect power amp to av
I presume you want to use it to drive speakers from a source controlled by the Denon??? Probably the Front channels? We'll assume that's it...
Run RCA cables from the Pre Out jacks to the NAD's L and R inputs. If it has a volume control, set the NAD to its maximum volume (for consistency *), run through the setup for levels and you're done.
* If it doesn't have a volume control it's already set to max. That's normal for power amps. Your receiver / preamp controls the volume fed to them.
BTW: If you're thinking of using two sets of Front channel speakers simultaneously you'll have to choose a level on the NAD that will match up with the others in volume.
Jan 22, 2010 | Denon AVR-3805 Receiver
Fender Deluxe. The volume knob has no effect whatsoever. Volume only changes with the drive knob.
Your amp has two channels - "normal" and "drive." When you are on the normal channel, the "volume" knob controls your gain. In the "drive" channel, the drive knob controls your gain. In both channels, the "master" knob limits how loud the amp will get.
Most likely, you are on the drive channel, so the volume knob will have no effect. Try pushing the "channel select" switch. You should notice the channel indicator lamp (next to the drive knob) turn off. When it is off, you are in the normal mode. Yellow = drive, and red = "more drive."
Experiment with different settings to get a variety of tones.
To get the most out of this amp, try reading the manual, available online here:
http://www.fender.com/support/manuals/pdfs/manuals_elec/guitarpdf/Hot_Rod_Deluxe.pdf
Have fun - it's a great amp.
Oct 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
No volume control
lower the volume of the cd player
May 08, 2009 | NAD C320 2-Channel Amplifier
Sound through one channel
Only the right channel had a sound,the left channel is mute, whatever adjustment you did and whatever balancing you done nothigs happen,even you interchange the speakers. The problem is in the power amp. The STK IC there is busted already, it's better to change it with a new one so the performance become normal again.
Jun 14, 2008 | NAD C372 Amplifier
I have a PVX 20 preamp by gemini. the volume knob doesnt seem yo do anything. what is it suppose to gain?
Hi there - did you ever solve the problem? I have one of these and it only seems to have a gain of about 5. As long as you're taking your output from 'Pre Out' 1 or 2, the volume control should adjust from no output to max.
Apr 16, 2008 | Audio Players & Recorders
Alpine mrp-350 amp
1) If you bridge on a non bridged amp your sound will be horrible as they sine waves comming out of the two teminals will be different... I suggest removing the bridge. 2) The gain knob is to adjust when the amp will reach its max volume with respect to the sterio;s volume. 3) the LP filter is a Low Pass filter and its purpose is to eliminate the higher frequencies that do not sound all the well when played over subwoofers.
Feb 18, 2007 | Alpine MRP-M350 Car Audio Amplifier
 Grubhead
Grubhead
Marvin
Marvin
