Question about KitchenAid Kitchen Ranges
Replaced both the display board and the central appliance board but cannot get anything to work on the display
  • loucks_e Apr 27, 2010
    we have checked the power for this range , there is no problem with any of the top.
    thanks
    al
  • 2,019 Answers
Check power and ground connections to both. The display should work independently, it is either without one of these essential items.
But you need to tell me is they have their own transformers, of if they share power from a separate transformer unit?
The displays and controls are all 5 volt these days, instead of 120 volt.
Posted on Apr 27, 2010
  • Kirk Augustin
    Kirk Augustin May 02, 2010
    You say you checked the power and have no problem, but you did not say if you checked 110 volt AC, or 12 volt DC, 5 volt DC, ground, RF shielding, etc.
    This is not like the old days when you all you needed was to get 110 at the heating element.
    These days everything has an embedded computer and you need to supply exactly what it needs.
  • KitchenAid Master
  • 12,061 Answers
If you have done that and still No Go, then you most probably have a problem, in something common to both, and that is the Power Supply.
You need to get a Service Manual, for your exact make & model. I have included a "Generic" Range service and repair manual, which, will still be relevant to troubleshoot. but a manual exactly for your make and model, will have the exact, details, such as a circuit diagram, and such. However in saying that, it will be possible to fix, this, with the Generic manual, as they are all basically the same. So work through the troubleshooting procedures, and pay special attention, to the Power Supply, and any other "Common" to bath, faulty boards.
http://www.applianceaid.com/erange.html
http://www.acmehowto.com/howto/appliance/range/erange.php
http://www.repairclinic.com/Range-Stove-Oven-Repair-Help
http://frigidaireservicetips.com/pdfs/477_5.pdf
Above, is a generic range service manual, above that, DIY repair how to's, above that are other troubleshooting and repair websites, to help. BUT you really need to get one for your exact make and model, even if you must pay for it.
Posted on Apr 26, 2010
AEG L87480 on desplay makers E91 what means
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
After that the display will show one of the following errors that are more precise:
E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
E94 - Incorrect configuration of washing cycle.
E95 - Communication error between microprocessor and
EEPROM. Posible causes: Electronic board faulty.
E97 - Incongruence between programme selector and
cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
Dado
Jan 11, 2016 | AEG Washing Machines
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error E90 and starts beeping and stops working? Any ideas how to fix it ? Thanks kindly
Dado
Feb 12, 2015 | Electrolux EW1000i Front Load Washer
I've been a appliance Service tech a while now.
Check wiring, the boards may not be getting voltage.
Jul 30, 2017 | Washing Machines
Had F70 &F71 changed ccu and ui won't power up just beeps
Even after they replacing the CCU and the MCU, I still kept getting the three beeps and the F70 Error... the fix was replacing the front controller boards (where the knobs and buttons are). check your connections also, and that they are in the proper slot.
Oct 31, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
No power... reset outside on ac unit, checked to see if the water was not draining "clear", the digital display not showing anything
Check the 2 wire that runs from inside unit to outdoor unit for damage. Then check the indoor unit for a circuit board with a blown fuse. If no display it means no 24 v is going from heater to thermostat
May 12, 2010 | Ruud Central System Air Conditioner
Oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Mar 06, 2010 | Whirlpool RBD305PD Electric Double Oven
GE SXS Fridge/Freezer
if the fan in the freezer compartment is not running theres a problem.
verify power to the fan motor, if present replace fan motor.
if not hopefully theres a wiring schematic/diagram so you could trace that circuit back to the control board and verify whether thats bad or not..
WR55X10942 - BOARD ASM MAIN CONTROL
generally though if the fan by the compressor is running the fan in the freezer should also be spinning and have power..
by the way, it states in the parts listing that it is a dc motor
WR60X10074 - Motor DC Evaporator Fan
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | GE GSS20IEP Side by Side Refrigerator
JenAir SVD48600W clock display is out.
They were known for bad display boards. Changing the display should solve it. Take the model number to and appliance store and have them look it up and order it.
Sep 01, 2009 | Kitchen Ranges
Display pannel does not display/work
I had the same problem... fading on the display. Replaced the display internal panel. It is a common part with other major appliance manufacturers. The problem was corrected.
Mar 23, 2009 | Jenn-Air JJW8527C Expressions Collection...
Display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
determined from whirlpool that the f2 display is from the control circuit board. the board's problem is intermittent and needs eventually replacing. not covered by warranty. determined that whirlpool has reduced the warranty for the electronic circuits in its appliances from 5 to 1 year. this is great for consumer confidence in whirlpool. have had trouble with 2 other new whirlpool appliances. probably will not buy another whirlpool appliance.
Aug 01, 2008 | Whirlpool GH5184XPQ Microwave Oven
Open Questions:
Kitchen Ranges Logo
172 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
