Question about Maytag Ensignia MAV3757AWW Top Load Washer
My maytag washer
My washer doesn't spin
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 27, 2010
I have a maytag pav2300 pump will not pump
see this causes:
It spins, but doesn't pump
drain line is clogged, remove some sock with pliers+test the pump for defective propeller, and replace DO NOT REPAIR
It doesn't spin or pump
frozen pump puller +and replace the pump
It pumps, but the water returns
if the drain hose reach more about 4 inches, cut of the excess
if the hose is lower, install air/gap siphon break assembly
see the diagram.
God bless you
Jun 29, 2012 | Maytag PAV2300 Top Load Washer
Maytag Neptune rotates but not in spin mode
see the causes:
t doesn't pump or spin
frozen puller or belt broken pump, lid switch defective
It pumps, but doesn't spin
lid switch defective+motor coupler defective+belt broken+clutch worn+drive motor faulty+transmision not shifting properly+basket worn.
It spins only with the lid closed
lid for security reason.
see the diagram
Jun 19, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
My washer fills, agitates but will not drain
Does your washer spin? If yes, and it doesn't drain it most likely a failed/plugged pump.
If it doesn't spin it could be a belt or timer issue..
Sep 15, 2011 | Maytag MAV2755AWW Dependable Clean Top...
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
My Maytag washer m.mtw58701tw0 doesn`t drain or spin and I just replaced the motor with a new one. What could be the problem?
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. Please rate my answer as 4 thumbs up. thanks. Joe
Oct 02, 2010 | Maytag Washing Machines
Neptune wont spin
Looks like I may have to post this as a solution to get the link to you. I never tried to put a link in a clarification request.
Click on this Forum. If that doesn’t work here is the link to paste in your browser.
http://www.fixya.com/support/p46844-maytag_neptune_mlg2000a_front_load
Jul 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Ensignia MAV3757AWW Top Load Washer Logo
151 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
