How do i assign a record player to ''aux ''input terminals of a denon avr 1507 amplifier
    Brigadier General:
  • 8,546 Answers
Depends on the record player (turntable). If it's old-school it will need a PHONO preamplifier to raise the level and frequency-balance the output according to the RIAA curve. Otherwise it will be uselessly low in volume and tinny sounding.
Phono preamps are available at a lot of electronics stores online. Google it. If you have an old school receiver with a PHONO function you could use IT for the TT and send its output to the Denon.
If it's a newer TT it may have its own internal (selectable) preamp. Then it would drive any standard Line Level audio input.
Posted on Apr 28, 2010
Onkyo DX-C390 with Denon AVR-S710W? This doesn't seem to work when input to the amplifier's media player audio inputs. Do I need a preamp?
Both of the devices have optical connections, by getting a lead between the two you should hear the high quality sound from the unit. Make certain the optical connection is switched on and assigned to the Onkyo.
Only a record player requires a pre-amp. If it the amp doesn't have a dedicated socket for it.
Jul 04, 2017 | Denon Audio Players & Recorders
DENON AVR 1507 short?
unplug it, let it set for about 15 min., plug it back in and see what happens. Hopefully it will recycle itself. If that fails, with your theater remote, you can pull up it's functions screen on your TV, and probably return it to factory default settings. That would be a last resort for me before seeking professional help. Good luck. . .
Jul 27, 2017 | Denon AVR-1507 Receiver
Denon AVR-2802 Optical Issue
If you look at page 16 of the user manual it tells you how to assign the devices to the optical connections. Once this is done it should work.
If you don't have the manual just type "denon avr 2802 manual" into Google and it will show a free PDF file of it. On my search it came up first!
Feb 09, 2018 | Denon AVR-2802
Denon AVR-1507 speakers don'twork is there something I can reset
Yup, don't guess, read. Lots of things to set.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-1507-Receivers-manual/id/696ci071/t/2/
Mar 14, 2011 | Denon AVR-1507 Receiver
Tell the difference between the Aux input and V-Aux input
'Aux' is a general label for any Line Level analog stereo input like DVD, VCR, TV, DBS, etc. They are usually electrically identical and interchangeable except for PHONO.
V-Aux on this unit is on the front panel for conveniently connecting a video device. It has analog and assignable digital audio plus S-video and composite video.
There is nothing labeled 'Aux' on this unit.
Feb 16, 2011 | Denon AVR-2807 Receiver
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Can't get sound connecting Nintendo WII using component cables
green, blue, and red for video, white and red for audio.
Dec 03, 2017 | Denon AVR-1707 Receiver
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
Where do I connect passice subwoofer
How many terminals does your s woofer have?
accordianman
Nov 01, 2007 | Denon AVR-1507 Receiver
77 people viewed this question
 Grubhead
Grubhead
