Question about Kenmore 33169 Gas Single Oven
I don't have a Kenmore I have a Fridgidare and I have burned on foil on the bottom and cannot remove it. It is a self cleaning overn and I am afraid to turn it on??? I have tried scrapping, soaking, but nothing is budging??
  • 4,059 Answers
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you money to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Posted on Apr 26, 2010
1How do I remove small pieces of aluminum foil which are stuck to the bottom of my oven? 2 If I can't remove the small amounts of alum. foil, Will still be able to use the self-cleaning feature?
Hello Wendy;
My name is Peter. I am a retired field service appliance technician.
You can try to use a putty knife.
When your oven goes into the self cleaning model, you are burning off grease. The burning off of aluminum foil is nothing compared to burning off the grease.
You may see some small flame. But, this will soon pass. Your cleaning cycle can handle this without causing any damage.
Mar 24, 2015 | Kenmore Ovens
MELTED ALUMINUM FOIL ON BOTTOM OF OVEN FLOOR: Have a Kenmore ceramic smooth top range. We placed a piece of aluminum foil on the very bottom of the oven as we like to bake our pizza on the rack but...
I would try a copper scouring pad.
Aluminium is very soft - Mohs hardness of 2.75
Copper has a Mohs hardness of 3, just slightly harder.
https://en.wikipedia.org/wiki/Hardnesses_of_the_elements_(data_page)
Ceramic tile has a hardness of 7
Mohs Hardness Scale
This means the copper scouring pad should be able to remove the melted foil without scratching the ceramic - but test first to be sure.
Mar 10, 2017 | Ovens
Burned foil on bottom of self-cleaning oven. Please help!!!!
Hello,Take some mild soap and water and lightly rub it in with a scouring pad. This should remove most of it if not all of it.
Thanks
May 28, 2010 | Kenmore 47783 Electric Single Oven
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Kenmore self cleaning oven with foil liner burned on!
Hi Leia, Unfortunately, the aluminum actually melted and adhered. The only perfect fix is to buy a new bottom piece for the oven, it costs about $30.00 and it is very easy to remove the old and install the new. Just a few screws.
You can get the part directly from sears by going to sears.com
May 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
1990 Kenmore Self Cleaning 24in Elec Double Oven - Top Oven door does not open
hit cancel or stop clear see if that helps if that doesnt work start self clean then stop it
Jul 29, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Kenmore 33169 Gas Single Oven Logo
407 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
