Question about Canon Laser Class 830i Plain Paper Fax
Canon Laser Class 830i Fax Machine reset to factory defaults.
I have a canon Laser Class 830i. We set up a user name and passcode and now we can't get the machine to do anything.
Is there a way to set the machine, or the passcodes back to factory defaults?
SOURCE: Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Posted on Jan 26, 2009
greg_margo
  • 1959 Answers
SOURCE: Updating a Group Fax
Assuming the group name will remain the same, you can edit the Sender's name and/or phone number by doing the following:
  1. Go through the procedure to Add a Contact or number
  2. When you reach that Contact, you can edit by pressing the < key to move through the name or number
  3. Press Delete key to remove the name and re-insert the name/ same process for editing the number
The process is as follows to get to the option you need:
  1. Open all three one-touch dialing panels
  2. Press Data Registration
  3. Use up down arrows to get to Add. Registration
  4. Use up down arrows to get to Touch Spd Dial
  5. Use up down arrows to get to the desired Contact name or number
  6. Use side arrows to move cursor
  7. Use Delete key to remove and re-enter Name and/or number
  8. Once the name/number appears as you want it, Press "SET"
This should change the name/number individually and in your group.
Best of luck.
Greg
Posted on Jun 17, 2009
iservice
  • 318 Answers
SOURCE: Confirmation for a fax that is being sent
Press the menu(dataregistration button) go to report settings under Fax settings edit TX report,change it to - output yes.
Posted on Sep 11, 2009
SOURCE: Canon Laser Class 8500
power supply
Posted on Nov 26, 2009
iservice
  • 318 Answers
SOURCE: how do you print an activity report from a canon
Press the funcktion button then the report button activity report will be displayed press set.
Posted on Dec 06, 2009
We have a Canon 810 Fax Machine. How can we change the fax header?
change unit name
press additional functions button
then use the arrow - + buttons to select
tx/rx settings press ok
tx/rx common set.
tx settings
unit name
http://downloads.canon.com/cpr/pdf/Manuals/lc_800_series_basic_operation_guide.pdf
page 333 or section 12
Oct 28, 2016 | Canon Laser Class 810 Plain Paper Fax
How to program TX report on a canon laser class 830i
You can find instruction on how to configure Transmission Reports on page 364 of the use guide. (see below)
Hope that helps.
Dec 19, 2014 | Canon Office Equipment & Supplies
How do I print the configuration page from the canon Laser class 830i fax machine
I am using a mac, and not the same brand printer, but I go to my system preferences, pick my printer, go to the top and pick "Options and Supplies" a new screen should open. There should be a "test" icon, as well as options for allignment, cleaning heads,etc..
Nov 19, 2014 | Canon Office Equipment & Supplies
I am getting a feeder glass dirty message. I have cleaned glass and rollers. Do I need to reset
look the cartridge is there some defect.and then do the reset.Its not anything big failure just the printer sometimes mix the right info.
Jun 05, 2014 | Canon Laser Class 830i Plain Paper Fax
Canon Fax User Manual
hi
I need to CODE reset factory default printer
model : CANON L150
Apr 23, 2013 | Canon i-SENSYS FAX-L150 Laser...
Our RX report for our Canon 830i fax machine lists a transaction failed (NG) with error code #0106
This error usually means you have a phone line problem.
You need to try to increase your transmission level, or check the line equalization. It could also be a problem with an echo on the phone line.
Dec 16, 2009 | Canon Laser Class 830i Plain Paper Fax
Photo copys are intermittently coming out black without copier settings being changed
you need to watch the exposure lamp under the glass . see if it goes out during a copy run. if so you may have a bad lamp, wires, invertor or pcb. if it does not go out you may need a drum, chagre replacemnet or developer. you may need a tech to look at it.
Oct 27, 2009 | Canon Laser Class 830i Plain Paper Fax
Canon fax/copier
1 Data Registation
2 Set
3 Set (when User Settings displayed..includes date, name etc.,)
4 Time & Date
5 Set etc..
Nov 15, 2007 | Office Equipment & Supplies
Canon Laser Class 830i Plain Paper Fax Logo
544 people viewed this question
old marine
old marine
