Question about Whirlpool Calypso GVW9959K Top Load Washer
How do I fix my washing machine when it flashes FL on the screen
  • 4,059 Answers
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Posted on Apr 26, 2010
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
My machine is flashing with the code FL, what does tha mean and how can I fix it?
The "FL" error code is indicating an overfill condition which is most likely due to the unit not draining properly or the pressure switch did not reset after the water was pumped out.
Mar 21, 2011 | Washing Machines
Kenmore Elite top load washer will not begin wash cycle and keeps flashing "FL" and beeping twice every few seconds. Tried unplugging it to see if the electronics would re-boot. How can i correct this...
Hi
Thanks for using FixYa. Error LF or FL means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Kenmore 24032\24036 Top Load Washer
How do I fix the FL ERROR CODE?
FL = Flood condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
hope this helps
Aug 11, 2010 | Washing Machines
Washing machine keeps beeping when i try to start it and it goes from the minutes on the screen to do to FL ?? ive tried turning it of and restarting it ?
Hello there: FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Press STOP/CANCEL to clear the display. You may want to have the water level sensor replaced cause this will cause this condition if it is faulty ok
Hope this is very helpful for you
Best regards mike
Jul 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
The wash machine stopped working and is flashing FL
Jun 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Calypso Whirlpool washer
FL= Flood Condition
realize that the trio was due to an
overfill condition instead of a suds lock
condition in order for FL to be displayed.
time out. The pump is cycled in drain mode
for 30 secondson 30 seconds off untill the
Note: Press STOP/CANCEL to clear display on all error codes
Causes of flood condition. Inlet valves
stuck on, Sediment in water level pressure
tube.
Other codes:
PF power failure
Er control lost settings during PF
LF Long fill Clogged inlet screens
CE Com error between motor and control
Ld Long drain Clogged/slow drain/pump
CA/CI Motor amping up
ob off balance load
Sr relay failure no control to motor
LS Lid switch no signal from lid switch, error occurs if the motor and control disagree as to the position of the lid switch. Usually means corosion is buit up in the switch and the motor knows the lid is shut but the control does not. Cose appears when start button is pressed.
open lid= flashing display time If the lid is opened time remaining flashes in display. Close lid and press start to continue.
SL Suds Lock Current draw on motor is sensed by motor control and a suds lock is declared The control trys 3 times to fix this by doing a mini cycle, SL is displayed if the unit was unable to correct the problem. This problem is caused by:
Bad pump
Extra heavy load
Excessive detergent
or Excessive suds/wrong stuff
Feb 04, 2010 | Washing Machines
Every wash cycle FL shows on the screen, I have to extend the spin cycle to get all of the water out.
FL
Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Check the over fill switch hose for weakness or, damage if the FL code continues. if the hose is ok, replace the Over fill switch..
Jul 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Can not clear the FL code. Want to fix machine don't know where to start. Diagrams would be helpful.
This is a flood condition.
If it continues, simply replace the over fill switch.
May 28, 2009 | Whirlpool Washing Machines
Washer problem
Washer flashing FL. Still has some water in tub. Won't completely drain. Washing not functioning at all.
Jeff
Jun 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
