Question about Panasonic Video Cameras
Showing pre recorded tapes as unreadable format
  • 3,083 Answers
Were the tapes recorded on that machine, or another? If they were recorded on that camcorder, there is probably a problem with dirty heads, or possibly a bad connection with a ribbon cable inside the camcorder. There are good, instructive videos and articles about cleaning heads, and there are different ways. I prefer to spray them with a head cleaner, and then use the special chamois cleaning tips made especially for video heads. You can easily damage the heads, so read up on how to clean them, or have someone service them. It is a delicate procedure, and best to read up on it, so you don't destroy the heads. If the tapes were recorded on another camcorder or device, there could be an incompatibility issue. That's about all I can think of, other than a hardware or software/electronic component issue. Hope this helps.
Posted on Apr 26, 2010
Problem with recording/playback
If it plays back a pre-recorded tape OK, then the tape head will be good. If it doesn't you might have problem, with either the head or the pre-amp stage.
However if it is playing back OK but not recording, then you have problem in the record circuit. Some tape decks physically switch the circuit when you press record. Pushing the record button will cause a switch to move position. In some cases dirt or dust can get into the switch and it doesn't connect properly. Switch cleaning fluid will correct the problem.
However the record circuit itself could be faulty. Perhaps an IC has developed a fault on one channel, which will need to be replaced.
Watching what happens when you press record with the top cover off, showing the workings, might point to some movement of the mechanism to reveal a faulty switch.
Jul 07, 2016 | Audio Players & Recorders
Not all cd tapes play clearly out of 12 tapes ,4 sound ok ,8 soundwrak
Are these all commercial pre-recorded tapes? Or are they tapes that were recorded at home? Is the tape deck one that the tape loads in from the short side and must be flipped around to play the other side....or is it one that the tape loads in with the tape facing in and is auto-reversing? Pre-recorded commercial tapes should work on most machines without problems. Home recorded tapes can be a problem, especially on the type of deck that the tape must be swapped over to play the reverse side. Many users use C90 or C120 tapes to home record. These tapes are thinner than normal tapes and are prone to getting overly tight and then can break and/or stretch. This causes jamming in the deck and distortion of the playback.
Jan 18, 2015 | JVC Car Audio & Video
Will no longer record answers because "out of
Hi, I would suggest that you get another tape. Because after so many recordings the tape will become unreadable by the machine. Replace the tape.
Aug 18, 2011 | Panasonic Lands Phones
My canon camera seems to work fine in record mode. The LCD shows the video and the timestamp, and tape is moving. Yet in playback mode no matter what Tape I use (even if I know the tape has video on it)...
The playback head is dirty. Insert a brand new tape into the drive and perform a record, through the entire tape until it reaches the end. Then play a pre-recorded tape.
Nov 13, 2010 | Canon VIXIA HV30 DV Camcorder
Blue screen on lcd screen
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
Nov 11, 2010 | Sony DCR-HC30E MiniDV Camcorder
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
I insert a disc that is pre recorded into side a and insert a blank cdrw into side b and its telling me unreadable disc?
Which one is unreadable? The pre-recorded disc must have been finalized. Where was it recorded?
The blank must have the word "audio" somewhere in its type definition.
Apr 02, 2010 | RCA CDRW120 2-Disc CD Recorder
How do I get my VCR to tape programs
Two things to check here. Lets verify the basic functioning of the unit. Have you tried playing back a pre-recorded tape? If so, please post the results here. I suspect that a pre-recorded tape will fail as well. If so, I'll post instructions on how to resolve the problem.
Please keep me posted.
Thanks,
Dan
Dec 30, 2008 | Sony SLV-N55 VHS VCR
Recording problem on VCR
try cleaning the heads in the vcr. also use a new tape at least once a week.
Oct 21, 2008 | Televison & Video
Video Cameras Logo
70 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
