Question about Sennheiser SKM100 Wireless Handheld Transmitter SKM135G2B Microphone
Broken On/Off Switch
Where can the replacement on/off switch be purchased for the SKM 100 wireless handheld transmitter and is the procedure on how to replace it available?
Yes, the switch is available from Sennheiser parts, and if you can get to it and know how to work with SMD's, it's quite easy.
Posted on Jul 15, 2009
The on-off button has fallen off. How is this repaired? How much would a repair cost?
It depends on who you go to for repair. What ever you do do not take it to your local radio shack.
Mar 10, 2015 | Sennheiser SKM 2020-D-US Handheld...
Tip
How to program Chrysler Remote Transmitter
A Chrysler Transponder Key once programmed into a one car cannot be programmed to work any other car.
The transponder code identification is learned by the Sentry Key Immobilizer Module during programming. The Sentry Key Immobilizer Module sends the "Secret Code" to the transponder key and is retained by the transponder key during programming. After programming of the transponder key identification to the Sentry Key Immobilizer Module and the Secret Code is exchanged, the Sentry Key Immobilizer Module will ask for the transponder identification and the Secret Code every time the key is turned to ON or START.
No Emergency "Start" procedures for Chrysler vehicles.
Chrysler Key Operation and Programming
Model: 300 Year: 2005 - 2008
Model: 300C Year: 2005 - 2007
Remote alarm / central locking
System Operation
  • Pressing key LOCK button activates alarm and central locking.
  • Pressing key UNLOCK button once deactivates alarm system and unlocks driver's door.
  • Pressing key UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors and trunk.
  • Pressing trunk lid button twice opens trunk lid.
  • System will automatically lock all doors when vehicle is driven above 15 mph.
  • Additional functions can be set to respond to the transmitter.
Programming
When
  • Key transmitter added or replaced.
How
  • Key transmitter is programmed during immobilizer programming procedure.
Immobilizer
System Operation
  • Switch ignition ON.
  • Immobilizer warning lamp illuminates for approximately 3 seconds.
Programming
When
  • Keys added or replaced.
How:
NOTE: Two programmed key transmitters must be available for the following procedure to operate. If none available key transmitters can only be programmed using diagnostic equipment.
  • Insert first programmed key into ignition switch.
  • Switch ignition ON for at least 3 seconds but no longer than 15 seconds.
  • Turn ignition OFF and remove key.
  • Withing 15 seconds insert second programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will flash.
  • Turn ignition OFF and remove second programmed key.
  • Within 60 seconds insert non programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will illuminate for 3 seconds.
  • Switch ignition OFF.
  • Remove Key.
Check operation of programmed key transmitter.
Repeat procedure for additional key transmitters if required.
Model: 300M Year: 1999 - 2003
Model: Concorde Year: 1998 - 2003
Model: LHS Year: 1998 - 2001
Model: PT Cruiser Year: 2000 - 2005
System Operation
  • Pressing remote transmitter UNLOCK button once deactivates alarm system and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors.
  • Alarm / Central locking functions can be altered using remote transmitter.
Programming
When
  • Remote transmitter added or replaced.
How:
NOTE: One programmed Remote transmitters must be available for the following procedure to operate.
  • Obtain all remote transmitters.
NOTE: Any existing remote transmitters not used during programming will become inoperative.
Using a programmed remote transmitter proceed as follows.
  • Press and hold remote transmitter UNLOCK button.
  • After holding the UNLOCK button for at least 4 seconds but no longer than 10 seconds, press remote transmitterPANIC button for at least 1 second and release both buttons.
  • Ensure acoustic signal is emitted indicating programming mode active.
  • Within 30 seconds carry out the following procedure for each remote transmitter (including previously programmed remote remote transmitter)
  • Press any button of each remote transmitter to be programmed.
  • Ensure acoustic signal is emitted after each remote transmitter operation.
  • Programming must be completed within 30 seconds.
  • Switch ignition OFF or wait 32 seconds to exit programming mode.
Ensure final acoustic signal is emitted.
Replacement remote transmitters can also be programmed using diagnostic equipment.
Immobilizer
System Operation
  • System arms after switching ignition OFF.
Programming
When
How
NOTE:Two programmed key transmitters must be available for the following procedure to operate.
  • Obtain all keys.
  • Using first programmed key turn ignition switch ON and wait 3 seconds, return to OFF position and remove key.
NOTE: First and second programmed key operations MUST be performed within 15 seconds.
  • Insert second programmed key and switch ignition ON.
  • Wait approximately 10 seconds.
  • Ensure immobilizer warning lamp begins to flash and an acoustic signal is emitted.
  • Switch ignition OFF and remove key.
  • Within 50 seconds, insert new key and switch ignition ON.
  • Ensure acoustic signal is emitted and immobilizer warning lamp remains illuminated for 3 secondsindicating programming completed.
For each additional key repeat procedure starting from the beginning.
Replacement keys can also be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Chrysler Remote Control Programming...
on Mar 26, 2015 | Televison & Video
HOW TO REMOVE CIRCUIT BOARD FROM SHURE PGX2/SM58
First, unscrew the cartridge from the top. The round circuit board on top of the transmitter has a cutout on the switch side. Slide a screwdriver through that cutout and pop out the bezel the surrounds the switch. Remove the spring clip that is around the round circuit board and slide out the circuit board.
Apr 26, 2014 | Shure PGX-2 Wireless Handheld Microphone...
Vermont Castings (honeywell) remote not turning on fireplace. I replaced batteries. Is there a way to reset?
Yes, you can re-synchronize the transmitter to the valve. Turn the switch on the valve from "remote" to "local", then switch it back to "remote". Within 10 seconds, press the flame button on the transmitter to re-establish the handheld remote to the valve.
Nov 14, 2012 | Honeywell Televison & Video
How do I reactivate the wireless remote control transmitter for a 2004 Toyota Camry XLE? I replaced the battery and the transmitter still does not work.
To Program Wireless Remote Transmitters:
Begin with:
The driver's door open and unlocked.
Key out of the ignition.
1.Insert and remove the key from the ignition switch 2 times within 5 seconds.
Steps 2 and 3 should be performed within 40 seconds.
2.Close and open driver's door TWICE.
3.Insert the key into the ignition and remove it.
Steps 4 - 6 should be performed within 40 seconds.
4.Close and open the driver's door twice.
5.Insert the key into the ignition.
6.Close the door.
7.Turn the ignition switch from "Lock" to "On" and back to "Lock" at about 1 second intervals to select the desired mode:
1 time for ADD mode.
2 times for REWRITE mode.
3 times for CONFIRMATION mode.
5 times for PROHIBITION mode.
8.Remove the key from the ignition.
9.To confirm your mode selection, the power locks will now cycle "lock" to "unlock" a number of times corresponding to your key cycles in step 7.
If Confirmation or Prohibition modes have been selected, opening the door will complete the procedure.
10.For Add or Rewrite modes do the following within 40 seconds of Door Lock confirmation:
A.Press both transmitter Lock and Unlock buttons simultaneously between 1 and 1.5 seconds and release.
B.Within 3 seconds of step A press the transmitter Lock button for more than 1 second and release.
^If the transmitter has been successfully programmed, the power locks will cycle "lock" to "unlock" once at this time.
^If there are problems with the transmitter or the procedure up to this point, the locks will cycle twice. If this occurs, verify that you have received the correct transmitter, and then repeat the above procedure.
C.If multiple remotes are to be reprogrammed, repeat steps A and B.
11.Open the driver's door to conclude programming mode.
Sep 02, 2010 | 2004 Toyota Camry
How do I program or fix the key-less entry remote on my Expedition 1998 4.6? I tryed but the truck wont go into programing mode.
This is the procedure to Replacing lost transmitters
Take all your vehicle's transmitters to your dealer for reprogramming if:
1.- One transmitter is lost, or
2.- You want to purchase additional transmitters (up to four may be
programmed).
To reprogram the transmitters, place the key in the ignition and switch from OFF to ON eight times in rapid succession within 10 seconds. After doors lock/unlock, press any button on all transmitters (up to four).
When completed, switch the ignition to OFF. All transmitters must be programmed at the same time.
Hope thie help (remember rated and comment this). Good luck.
Mar 23, 2010 | 1998 Ford Expedition
Akg handheld transmitter not working after impact
Microphone capsules are very delicate and I'm afraid it sounds like you have broken yours and it will have to be replaced. Take the mike back to where you purchased it and see if you can get it serviced or if they can recommend someone locally who does that.
Sep 27, 2009 | AKG HT 40 Professional Microphone
Broken power switch
If you have a G1 SKM100 mic, the small on/off switch is an SKQLLC Tact switch made by ALPS. I don't know what's in a G2 or anything about the ones with the orange button. I just replaced the on/off switch and it took about 20mins. It's a bit fiddly but not too bad so long as you have a reasonably fine-tipped soldering iron. If you're in the USA then it look like there are a number of distributors who will sell one-offs. I'm in the UK and had to go back to the place I originally bought the mic from (DM music), who got it from Sennheiser and then sold it to me. For some reason Sennheiser wouldn't sell it to me direct. Good luck.
John
Dec 14, 2007 | Sennheiser SKM100 Wireless Handheld...
508 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
