Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Door water dispensor stopped working, ice side is working fine. Water side used to click when placing a glass against the actuator so I am guessing a switch has broken - where is the switch located/ can it be repaired?
  • 4,070 Answers
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Posted on Apr 26, 2010
All buttons on front of fridge work fine, all lights do their thing & all buttons do their thing EXCEPT for the actual cup dispensor button... no ice, no water. We replaced the entire unit containing...
Hi and welcome to FixYa, I am Kelly,
When both ice and water in door do not function the most probably suspect is the door / light switch. This switch is usually under $10.00 and is supposed to turn on the light when the actuator is extended and provide power for the water in door and the ice maker when the actuator is depressed. Your door switch is under the plastic TOP freezer door hinge cover and is item 406A of this diagram:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LSC26905TT/3204/0165000/50031613/00003?blt=06&prst=&shdMod=
PN: 6600JB3007B ($7.99) (Net image search the PN)
Image: http://www.rcappliancepartsimages.com/dbimages/00003487/01049105.jpg
The switch should have 3 wires on it labeled as follows:
C = Common (Power in)
NO = Power for water and ice in door when switch is actuated
NC = Power for the light when the door is open
If the actuator arm is damaged on this switch it will not function properly. But... it can just be a bad switch also.
Power off / unit unplugged continuity checks would be:
C to NC door open
C to NO door closed.
The cover is removed by carefully lifting up and outward on the side of the hinge cover. Place a putty knife on the top surface of the refrigerator so you don't scratch up the paint. Then use the screwdriver against the putty knife to coax off the hinge cover to gain access to the switch.
Inspect the wiring where it goes through the door also. This type of door switch wiring is notorious for wire chaffing where it passes through the chassis. Gently lift the wires up just enough to inspect for shorts. Then push them back into the unit.
One other thing to inspect is item 271 (Hinge lever.) It can be broken.
I really think this switch is what is causing your water in door and ice maker not to function. Just looking at images this switch may only have 2 wires on it but I still believe this is causing your problem.
Thanks for choosing FixYa,
Kelly
Jul 14, 2011 | LG LSC26905TT Side by Side Refrigerator
My ice maker works but not my water? Please help.
First check your hose and water source,going into the back of the fridge. Make sure they are bot clogged or kink in the hose.
Jan 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser will not work Just tried to get water from the dispenser.I heard a clicking when I pushed the lever in with a glass,but no water.I loosened the water line at the compression fitting at...
The ice works off of a different solenoid than the water dispensor . So , I would suggest this action : At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Jan 28, 2010 | Hotpoint Refrigerators
FRS26ZSH Water Dispensor Not Working
I have a GE 2005 Side by Side Refrigerator. Model GSS25JERF, Serial # FH242429. I get all kinds of Ice but no water. I replaced the water valve (p/n WR57X10050) and the Dispenser Display, 4 button ( p/n WR55x10443) Still no water dispensing from the water valve. What next ?????
Feb 28, 2009 | Frigidaire GLRS264ZA Side by Side...
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
ACTUATER PAD
Yes sounds like you need a new actuator pad. I had one do this this week and a new pad resolved it.
Dec 07, 2007 | Maytag MSD2432G Side by Side Refrigerator
No water at the door
If the solenoid valve doesn't click anymore then it's either bad or not activating anymore. Check that the switch behind the water lever is not broken or has fallen loose inside the door panel. You may be able to put a finger up there and try to push it without using just the lever. (sometimes slamming glasses into that lever over time breaks the switch attaching pins causing the switch to fall off inside). Take the front panel off and visually check that switch itself to see if it is still being held in place. Activate it by hand (not the lever method) and see if that water solenoid valve clicks again and water flows. If you have no water to both the Ice Maker and door dispensor at all (clogged filter?) check the main water line for clogs/debris, etc. If you are making ice still then water is at least getting to the ice maker and that means only the door water valve or switch is bad. The link below may help you "see" inside with the different diagrams, etc. http://www.partselect.com/MultiModels.aspx?ModelNum=GSL25JFP&searchTerm=&RefineSearch=0
Nov 20, 2006 | GE GSL25JFPBS Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
179 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
