Question about Apple 8X Dual Layer Super Drive (With-Out Brackets) for PB Titanium/Aluminum, Pismo, iBook G4&iMac G... (APP5691) Burner
Error code Ox80020063.Brand new drive. Disc has been burned but notice advised 'could not verify' and advised using another blank disc. The disk will not eject. When icon is dragged to 'trash' the burn symbol comes up with the advisory that 'will not fit on disc' because the disc is already burned.This is the SECOND TIME this drive has fucked up
    Brigadier General:
  • 3,513 Answers
I am sure you are working with MAC. Toast 8 has an option to disable the verify after writing. It's in Recorder Settings/Advanced, not Preferences.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Apr 26, 2010
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
When I try to burn data files to a CD-R disc on my toshiba satellite M1115, it repeatedly tells me to insert a disc, when I have put a brand new disc in. I have used the drive to burn music discs &...
It sounds like you are trying to burn too much data onto the disk. If you want to test this theory, you can burn a small amount of data to a blank CD-R to see if it works. If it does then you do not have a hardware problem. This will be good news.
There are different sizes of CD-R media, 650MB, 700MB and larger sometimes. If you select 700MB and try to burn to a 650MB media disk, the drive will just spit out the blank disk so as not to ruin it for a future burn. Also, if you are going to make a multi-session disk (or you have accidentally selected multi session, then you will automatically waste 22 MB leaving you 650-22 /628 MB, or 700-22 or 668 MB of space to burn your data. Each additional session will also take up 22 MB of space.
There is also a chance that the media you are trying to burn to is not compatible. Some lower end brands do not use enough reflective material for some burners. You can test this theory by trying an alternate brand of media.
Aug 30, 2011 | Toshiba Satellite M115-S3094 Notebook
Error : 10-FC12-0570 when i try to reinstall with the cds
Error 10-FC12-0570 on Toshiba satellite This error message means that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try copying the second disc using another system. If it's impossible: order for a new disc. If you can copy it, try using the copy to do the restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista Recovery Boot Cd is available free by Microsoft). Download it burn the Image .iso and run that disc. That disc will not restore the OS: run diagnostics on the HDD; once disk check is completed and repaired, proceed with the Recovery disks that you have.
Nov 22, 2010 | Toshiba Satellite A215-S7422 Notebook
Dvd drive will not read burned discs
The laser is weak and its not burning discs properly to begin with. Get a new drive put in there and that will take care of the problem cause a new drive will have a new laser in it.
Aug 22, 2009 | Gateway Computers & Internet
Error code 204 when backing up to DVD on Acer Aspire 5515
i was having same problem.  went home and tried again with a different brand of dvd and it worked on the first try.  definetly a different brand and not sure but i think the one at work was just a dvd-r  the one i am using at home that worked is an RW.  maybe the process writes something again so you need this kind of disk.  hope it helps.
Apr 07, 2009 | Acer Aspire 6930-6455 Notebook PC
Disk Drive spits out brand new DVD+R DL cds
The drive in the G5 may not support DL discs. Open the system profiler (From the apple menu, select 'About This Mac' then select 'More Info'). Click on 'Disc Burning' in the left hand column. You will now get the details about the disc drive including which discs are supported.
Jan 07, 2009 | Apple Power Mac G5 Desktop
E-4 54040990 Cannot record on this disc
I had this problem with my Toshiba DVR16 recorder; I was unable to format new DVD-RW discs even though old ones worked fine.
Initially I thought the laser lens was dirty, but no amount of lens cleaning helped. Then I thought the rated disk speed must be to blame, since it was some 4x disks that first presented the problem. But then I tried 2x disks and the problem persisted. So some aspect of the manufacture of these disks must have changed in recent months.
Anyway, the solution I discovered was to perform an 'erase' operation on each disk using a program on my PC called ImgBurn. This is a free program, which can be downloaded from imgburn.com. Just select Tools > Drive > Erase > Quick. Once that's done (it only takes seconds), take the disk out of your PC and pop it in your DVD writer, whereupon it should start its own format routine.
This has worked for me on 3 different brands of disk (Sony, Memorex, Datawrite). Which is just as well, as I was on the verge of throwing the DVD recorder out of the window. Hope it works for you.
<Neil G.>
Sep 29, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cdj 800 error 8301
Error Code
E-72 01
E-83 01
E-83 02
E-83 03
E-91 01
Description
Player unable to read TOC data.
Disc is rotating, but rotation cannot be ascertained.
Player unable to play back currently inserted disc.
Mechanical operation has failed to complete within
specified time interval.
Possible cause and recommended action
Disc is cracked.
= Recommended action: replace disc.
Disc is soiled or dirty.
= Recommended action: clean disc.
If other discs play normally, the problem is with the disc itself.
Dust or some other form of foreign particles have found their
way into disc insertion slot.
= Recommended action: remove dust or other foreign particles.
Error Type
TOC READ ERROR
PLAYER ERROR
MECHANICAL TIME OUT
Jun 11, 2008 | Pioneer CDJ-800 Turntable
Cd/dvd drive problem
Try with another brand of disk; the Matsushita UJ870 drive of our 5315 burn my Sony CD's but not my Philips CD's (my Compaq V2617LA with an older Matsushita UJ840 drive has burned Phillips CD's in the last two monts)... Remember: CD and DVD lassers are different. I think because of that, i haven't see problems with Sony, Philips and Samsung DVD's... only with CD's...
Jun 04, 2008 | Acer Aspire 5315 Notebook
Optiarc DVD RW AD-5170A ATA not writing DVDs
sounds like your file is to large by the time it writes in and out or the disks a not to great
Mar 02, 2008 | Computers & Internet
Apple 8X Dual Layer Super Drive (With-Out Brackets) for PB Titanium/Aluminum, Pismo, iBook G4&iMac G... (APP5691) Burner Logo
265 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
