Question about DeLonghi PAC C100 Air Conditioner
DeLonghi PAC L90
Hi, it stopped working; light came on.....blinking "FE" (but there is no line at the top of the E - so whatever that symbol is). Thx, Dee
    Brigadier General:
  • 6,966 Answers
I would venture that your unit requires cleaning of the filters or at worst it may be a fan motor. Initially, try removing the front panel holding the filters and clean it as instructed in the user's manual. Should this not be corrective, i would suggest to seek the services of a qualified professional
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 24, 2008
PAC L90 air conditioner keeps frosting up. The room air intake frosts up completely, blocking all the air.
Air conditioners frost up when there is a lack of air flow. Clean the filter, check if a belt is broken (if any), check that the fan spins freely, check all in ports and out ports for blockage and clean the coils with mild soap and water.
Jun 08, 2016 | DeLonghi PAC L90 Portable Air Conditioner
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
I have a pf code flashong on my a/c unit. Could you tell me what it means. I have the PAC l90
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Sep 24, 2010 | DeLonghi PAC L90 Portable Air Conditioner
I have a Delonghi PAC A110L that has stopped working. When you plug it in it starts up but then powers down giving an error message that looks like FE but with the top line missing from the E
The unit is full of water at this point. If it is real humid it can not get rid of in fast enough via the air duct. Look for plug in back low. Watch out, have unit outside or a low pan to catch water when you pull the plug.
Jun 12, 2010 | DeLonghi Heating & Cooling
Help please...blinking FE but E does not have top line to the right
Check that the error is not Ft, that means Full Tank.
Drain the internal safety tank through the drain hoses by opening the cover on the rear of the appliance.
there you will find two drain hoses,pull them out, take off the caps, and let all the water flow out.
When finish draining the water place the caps and the hoses back in place.
You also need to clean the filters and let them dry before putting them back in place.
Here is the user manual, see self diagnosis section.
Sep 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
PAC L90 water tank capacity
when tank is full you will get the letters FE will signal a FULL TANK
(The tank is full)
You have it setup to constantly drain GOOD.
Should you should not plug the drain hoses to get colder air.
Do let it drain . It is more convenient!
If the unit is the proper BTU for the square footage of the area to be cooled it will be cold!
If the tank gets full you will not get cool air?
Please remember to leave a rating before you go!
Thank you
Jul 28, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
May 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
FE Light
You need drain the water and then function normally.
Sep 23, 2007 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi PAC C100 Air Conditioner Logo
372 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
