Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Where can I get the manual for the kenmore 3.5 super capacity washing machine?
    President:
  • 1,937 Answers
See the following site:
http://www.managemyhome.com/
Click on the Manuals tab, enter your model number and you should be able to get PDF files of your manuals.
Posted on Apr 26, 2010
catriver
  • 878 Answers
SOURCE: Washing machine Kenmore 3.2 cu ft Super capacity plus top loader
fabi, if Im reading you right the machine fills with water and just sits there. Can you hear the motor running when it should be agitating? If so you might have a broken coupler. If the machine is quiet and just sits there, it could be the pressure switch. The first picture shows the pressure switch with the rubber hose and purple wire going to it (far left). There is no model number posted but this is a top loading Kenmore, should be close. Take the rubber tubing off the switch and blow into the switch with another piece of tubing. Does it start agitating? If so, there's your problem. If you do hear the motor running and it's not agitating it may be the motor coupler. If you need more assist...email me at catriver1@gmail.com Catriver..post back.
Posted on Feb 05, 2007
thydzik
  • 86 Answers
SOURCE: What is the cu ft capacity of a Kenmore Series 80
The capacity of the Kenmore 80 series is 3.0 cubic foot. The 90 series washer is 3.2 cubic foot.
Posted on Jul 16, 2009
  • 403 Answers
SOURCE: kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Posted on Oct 05, 2009
SOURCE: Kenmore super capacity 3.5 not draining and I
I just had the same problem 1 month ago. You have to replace the locking mechanism. Its not to hard of a job. I'm no handy man and I was able to do the job. I went to sears to order the part and it cost me about $60.
Posted on Mar 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: My washing machine won't start
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Want an owner manual for an old Kenmore 70 series washing machine havy duty super capacity plus mod. # 110 22722101 ser. # CL4432583
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's manual is listed in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Mar 07, 2010 | Kenmore Washing Machines
Kenmore washer 3.5 super capacity. Machine spins
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Kenmore 3.5 super capacity. will not go to spin
if the drive coupler is broken it won't wash or spin. Does it have a removable lower access panel on the front? if so its an amana. see if u can manually turn the transmission pully both directions. AND make sure there is nothing holding the tub ie nail through tub whole garment between tubs etc.
Jun 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
What is the capacity of my Kenmore washer?
3.2cu ft.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Rinse cycle do not disengaged
does it drain?did you check the lid switch?
May 17, 2009 | Kenmore Washing Machines
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
712 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
