Question about GE Spacemaker JVM1640SJ Microwave Oven
Recently replaced under microwave bulb while light was on (should have been off). Loud pop and now lights under microwave and vent don't work. Fuse issue?
  • GE Master
  • 3,740 Answers
Yes it is a fuse issue. Inside the microwave chassis if you follow the power cord to the fuse block there will either be a 15 A or 20A fuse.
The fuse is Item 47 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5227571&diagram_id=22974429#d22974429
close up:
http://www.appliancepartspros.com/part_details.aspx?part_id=2631556
BEFORE you replace the fuse, check the light bulb socket contacts. Most likely when you changed the bulb the side contact was somehow forced onto to bottom contact. Correct that problem first, other wise the fuse will probably blow again.
You can obtain the fuse at most any Appliance Parts source or Hardware outlet.
I have to ask... Does the microwave work but the fan motor does not? If that is the case you could have damaged the relay on the control board.
Your feedback would be appreciated.
Thanks for using FixYa,
Kelly
Posted on Apr 26, 2010
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
Went to replace the bulb under the microwave and there was a loud 'pop'. Then the microwave was dead. Did not trip the breaker, and checked the fuse inside the microwave, and it is still fine, and so is...
< -- I see and repair this on a regular basis. Details are here .
This failure occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line, as the warning label near the light socket advises.
Feel free to contact me for more information.
Feb 16, 2014 | Goldstar MV-1501 Microwave Oven
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
How do I replace light bulb
Do you mean you want to replace light bulb for your microwave? If yes follow the instructions below;
  1. PLEASE UNPLUG YOUR MICROWAVE!
  2. Picture of your microwave with a phone or camera so that you don't forget how to assemble it back.
  3. Remove the two screws that holds grill. They are located at the edge of the unit. Once the screws are out, rotate the grill forward from the top. It will pop right out.
  4. Once the screws are out, rotate the grill forward from the top. The grill should pop right out.
  5. Locate a small access cavity on the left.
  6. Remove the screw that is located near the front of the microwave door.
  7. Lift up the sheet metal floor to access the bulb. The bulb is located under the sheet metal "floor" on the left.
  8. Place a flash light on the microwave floor and shine the light in the light area. This will help you see better when you replace your bulb.
  9. Look for a small shiny reflector that hides the bulb. Use your two fingers to squeeze it a bit. Making sure not to bend it.
  10. The bulb connection should come right out.
  11. After you replaced the bulb, re secure the reflector and the sheet metal floor with the single screw. Test the bulb by plugging in your microwave.
  12. Once you see that the bulb works. Unplug your microwave again and re attach the front grill. You are now done.
I hope this helps to solve your problem.
Good luck.
Apr 08, 2011 | Daewoo Microwave Ovens
The second under cabinet light went out with a pop, and the vent fan went out with it. Is there a fuse for both somewhere? The turntable motor and light and fan still work. Will th vent fan come back on if...
There is a varistor or thermostat switch mounted on the wall behind the control panel. I unpluged the leads and shorted them together. the fan and lights started working again. I got another microwave off freecycle.org for parts. I noticed a lot of sites tend to point to the control panel for a $36 to $100 board repair. Don't fall for it. H.G.
Jan 03, 2010 | GE JVM1660 Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
The vent fan and surface light do not work
1. Check your circuit breaker for this m/w. Reset it.
2. Microwaves usually have 20A fuse inside. It could be broken.
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cooking light inoperable, everything else working fine
just did further testing...I stated incorrectly before, appears to be one/both relays for this light
Nov 12, 2008 | Whirlpool MH1150XM Convection/Microwave...
Model JVM130G
what brand is this and did the light go on when the door was opened before you changed the bulb?
Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpaceMaker JVM XL1800
Sounds like the ERC board failed. It maybe covered under warranty, check that first cause a new ERC could cost around $150-$200. Anything electric can cause the .."what the*^&% just happened syndrome.
Dec 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
153 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
