Question about Garden
B&S motor won't run 1981 model 422437
its not the crab as i just put a new one on i
bought tractor from another party , it was pop-in and back firing and
of course spiting gas back, but was running i order new carb put it o
n and at 1st it ran good for about 20 min then started the same as before ,
now i can't get it to start at all unless i disconnect the fuel line and w
ait awhile , then of course only till it drains bowl, it is blowing f
uel out just turning the motor over
  • 54 Answers
From what you describe it sound as though you have a bad valve, either the intake causing compression blowback or exhaust not opening.
Posted on Apr 28, 2010
I have a Sears FF18 1980's model tractor. #422437. My problem is getting oil in the breather
your oil rings are going bad might want to look at replacing it .
Jul 12, 2016 | Sears Garden
Ford Tractor model 8240 wiring or troubleshooting diagram please
go in google and put in these words
and look for or slick on this link Ford 7740 tractor wiring - free eBooks download - GoBookee.net
Jun 26, 2013 | 1981 Ford F 100
Can a chevrolet motor and transmission be put in a 1980 to 1985 Ford F100?
yeah with motor mount change & trans. mount change little bit of wiring issue it will run fine. they put chevy engine in ford mustang all the time that why they run run so quick
Dec 06, 2010 | 1981 Ford F 100
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 1982 yamaha 650 seca turbo. I just bought it and was gone for two week on vacation. pon returning, my motocycle leaked gas from the exhaust pipes. So I cleaned my carb. Boiled it in lemon...
When the carburetors over flow enough to fill the exhaust, It is possible that the gas also went into the cylinder and flowed past the rings and into the crankcase. With the engine overly full of gas and oil you could easily pop a seal or blow out a gasket. Check your oil level. If it is too full , change the oil, it will not lubricate properly with all the gas in it. Check that your shaft seal has not popped out. Check the air filter, the breather may have blown oil and gas all over it when you started the bike. Empty your pollution tubes behind the motor( they will drain the air box). Get in the habit of turning your fuel petcock off when not riding. This gas flooding happens randomly in certain models but can happen to any one.
Sep 07, 2010 | 1981 Yamaha XJ 650
Major Timing problems
check for vaccum leaks and make sure accelerator pump in crab is good,most likely il bet that crab needs rebuilding,also chcek your timing,hope this helps.
Oct 06, 2009 | 1981 Ford F 100
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
