Question about Kenmore 23.1 cu. ft. Side-By-Side Refrigerator w/Acceler-Ice & SpaceSaver Ice System
I have a kenmore side by side with spacesaver ice storage. The dispenser is broken. I have isolated the problem to the pot metal piece at the bottom of the storage container that drives the dispenser. It was held on with a single screw, and transfers the rotation from the drive motor to the storage container. Where do I find parts to repair this unit.
It is part number 920919 from repairclinic or any other appliance place. $5 to $9 bucks.
Posted on Aug 10, 2010
Removed ice bin had become clogged. after removing bin will not fit back on. do i need replace part?/
Posted on Aug 31, 2012
4 Suggested Answers
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
SOURCE: Kenmore water dispenser not working, side by side frig
no water come out of dispenser to glass
Posted on Aug 06, 2008
Kenmore coldspot refrigerator model 52552100 makes ice but wont dispense it
Below is a fix by another owner of your make and model for the same issue.
Pulled out ice bucket; tried ice dispenser with door latch pressed in and solenoid engaged and motor moved. Tried again and nothing (couple of times). Tried water...all good...good closure of dispensor flap (air pot operated). Opened dispenser (pried off carefully from bottom on this unit not to take off the glued part) and saw the micro-switch broken off of the ice dispenser side. Checked micro-switch (all good). Replaced control bracket...all good to go.
Nov 25, 2016 | Kenmore Refrigerators
How do I replace a plastic auger with a metal auger in a Kenmore side by side?
Fridge Dispenser Auger Drum Replacement - Whirlpool ...
? 4:56
www.youtube.com/watch?v=-fUJlQ1BQcs
Apr 12, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the dispenser auger drum is when ... Whirlpool, Kenmore, KitchenAid, Roper, Estate, Maytag, Crosley, ...
Sep 23, 2015 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
There's no water coming from the water dispenser
Have you ever replaced the water filter? It may be clogged. Does it make ice?
May 01, 2014 | Kenmore 23.1 cu. ft. Side-By-Side...
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
I have a Kenmore Side by Side Refrigerator with a space saver Ice storage system. The metal gear has broken that drives the blades. I need to replace that gear. How do I find what the part number is?
I belive the parts that you need are . for the vertical crusher .. and the upper piece is pt# 2220457 / lower piece (long) 2220458 . and replace the seal pt # 2198628 .. this chould correct your problem . this is for the ice storage bin that is on the freezer door . and is not for other models . all 21 throug 25's use this same unit. hope this helps mm ( feed back pls ..)
Aug 17, 2010 | Kenmore 23.1 cu. ft. Side-By-Side...
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
The auger on my ice dispenser is broken
you should be able to get it in metal mine is in metal check with your apliance parts dealer in your area thanks from gilles
Feb 04, 2009 | GE GSS20IEP Side by Side Refrigerator
Kenmore side-by-side only dispensing crushed ice
Hi blkshop,
Most likely the problem you are having is with the crushed ice solonoid. It is located in the back of the freezer behing the icebucket. The little metal arm from the icebucket goes into a hole, the hole is part of the solonoid. To make sure the problem is with the solonoid, first take the icebucket out and look at the little metal arm on the bottom. When you lift it, it will open for crushed or cubed ice in the bucket dispencer hole. If it works properly then the solonoid is bad.
This repair is sometimes a really hard repair, because it is so hard to get all the stuff out of the way to replace the solonoid. You have to remove the icebucket holder and most likely the icemaker, and on some models you will have to remove the fan and several other pieces to get to it. If you feel like trying the repair let me know, I can ship you the part, I keep almost everyone of those on hand, all I would need is your model and address. My number is (865)945-3808. or my email is mca0824@aol.com . Thanks and I hope this will FixYa. Michael Anderson
Sep 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker Trap door may be broken
I am having the same problem. My husband took off the front panel and we discovered there is a small piece of plastic holding the ice dispenser door in place that is broken so the door doesn't seal.
I called Sears to see if the part is replaceable -- it's not. I have to buy an entire freezer door for $464 because a .10 cent piece of plastic is broken.
This seems to be a common problem. My refrigerator is only 3 years old. Perhaps we need to make a complaint to Sears/Kenmore together.
May 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
1,150 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
