Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
Is this compatable w/windows 7?
Cruzer usb 2.0 flash drive 8gb it says everything but
    Scholar:
  • 62 Answers
The Short Answer to this is Yes. I have one and it works perfectly fine in windows 7. The only thing that does not work is that actual cruzer software itself. By this i mean that little window that comes up on xp comptuers. However you can still access it under my computer and you can still stop the device on in the tray icons. I hope this helps
Thanks
Steven.
Posted on Apr 27, 2010
Testimonial: "Thanks it nice to have expert support!"
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My 8GB SanDisk Cruzer when plugged in lights up, but it's not detected, both on Windows and on Mac, I don't know if it's still fixable... :(
Try reformatting your thumb drive. Here's how to do it on a Mac:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Feb 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My 8gb sandisk cruzer does not light up anymore and is not recognized.
SaveMyUsb.com can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 29, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
What format is the cruzer usb 2.0 flash drive in?
USB Drives are usually formatted as FAT or FAT32 drives
Nov 07, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I NEED A DRIVER FOR MY SANDISK USB, COZ I TRY ALL I SHOULD TO RECOGNIZED IT BUT AFTER ALL THE DISABLE, UNISTALL, RESTART, SHUTDOWN... STILL USN UNRECOGNIZED... WHAT SHOULD I DO?
Everything your Sandisk Cruzer USB driver needs to run should be on the usb drive itself, unless you have erased it, in which case you may have a problem.
The correct way to use a Sandisk Cruzer is to plug it in so that it lights up and then not touch anything on your computer until the orange sandisk symbol appears on your desktop. Right click this app and use it to browse your USB drive and eject it when you are done.
I hope that helps.
Aug 30, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
DELETE SONGS
hook it up to your computer and open up the files, then select the songs u want to delete and right click then select delete
May 13, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
Oct 20, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
146 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
