Question about Kenwood KAC-9152D Car Audio Amplifier
Amp will not turn on ,it has power to amp and power to p con, and it is eathed. i have checked fuses and they are ok.
Make sure to double check your remote wire and to see that it is connected properly
Posted on Apr 27, 2010
I dont seem to have a power supply to my Waeco air con roof unit
Check breaker at main panel. Check breaker if applicable in disconne t on roof. If this is a pull out disconnect make sure it is installed the right side up. If no issues with high voltage you may have a blown fuse on the low voltage side. Turn power off at disconnect, open machine and look for a small,blade style, like one for a car, 5 amp fuse that may possibly be blown.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 13, 2017 | Heating & Cooling
Headlight won't turn on
sounds like your fusible link blew .part of positive battery cable
Oct 16, 2015 | Cars & Trucks
Fans not turning on
check for power and eath at the fan terminal (engine hot)
if yes, replace fan motor,
if no, check fuse and relay for power/operation
if ok, check thermo switch is working
Jul 26, 2012 | 1998 Oldsmobile Intrigue
The l950t tv is power on and the screen is white totaly. Audio ok and channel change is ok
Check the connection between the logic board and the T-CON board on the LCD panel assembly, check the fuse on the T-CON board for 5vdc on the fuse of the T-CON board.
Look at LCD panel album to see what T-CON board looks like.
http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | Daewoo Lucoms L950T 19 inch LCD Monitor
1994 Cadillac Fleetwood, tail lights not working, brake lights fine, fuses fine, headlights fine, turn signals fine, bulbs tested ok.
If you remove the whole casing of the rear lights, you should see a single wire connected to the body / chassis of the vehicle. Remove the screw and clean the contact point by using a bit of sand paper. Replace the eath wire and test. In most cases the ground wire does not make contact correctly.
May 25, 2010 | Car Audio & Video
My Engiene Module fuse blows every time I gostart my 2000 Dodge Neon...there fore my car wont start.
Bad wiring, check the loom something is touching some where could be at the altenator at the back of the engine check the selinoid it's sending to much power or eathing out. Have a really close look at the wiring from the battery into the car and around the engine for signs of melting.
Jan 13, 2010 | 2000 Dodge Neon
Battery drain. alternator and battery ok. 30 amp fuse in front location shows arc. can't identify what fuse controls. is there a schematic which will show these fuses and their. purpose? ie coutesy lights,...
my battery drain indicator lamp is lit on my 2000 Toyota Camary. i checked the battery and have 12.5 volts when not running and 14.5 volts when running with lights & heater on. since all my other gauges are working ok i'm not sure if its a fuse or what fuse. can you help. altenator shows 14.5 volts when running.
Oct 26, 2009 | 2001 Toyota Avalon
I have a 2001 toyota corolla. The brake lights do not work, i changed the fuse & the brake switch. The lights still don't work, what else could it be?
Have you checked the switch for power? get a cheap test light and you should have power on one side of the switch all times.If you dont it will be a supply fault eg fuse, fusable link. does every thing else work,intieror lights, clock, haz, horn. if you have power on it check other side of switch when pressing brake padal, if so ceck for power at lamps with pedal pressed. if so check for correct type lamp or an eath problem. see how you go...
Jul 11, 2008 | 2001 Toyota Corolla
Kenwood KAC-9152D Car Audio Amplifier Logo
95 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
